October 23, 2023, 17:06 |
Roughness vs NoSlip in walls
I'm trying to understand how the NoSlip condition allows the program to read roughness, in this case, I'm assuming it reads roughness from the nut folder. Are my assumptions correct? if not how do these two parameters relate to one another? How does 0 velocity at wall translate to "there is some roughness here" |
October 23, 2023, 19:12 |
Rep Power: 10 |
I think if you need to assign roughness to your wall boundaries you'd need to use nutkRoughWallFunction assign to the walls in the nut file
checkout this if that's what you need https://www.openfoam.com/documentati...lFunction.html https://develop.openfoam.com/Develop...lMoving/0.orig |
roughness noslip wall |
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 08:13 |
Artificial wall error in fluent | aiden_1995 | Main CFD Forum | 0 | January 9, 2023 15:06 |
non-null velocity at walls despite noSlip condition | New_Old | OpenFOAM Running, Solving & CFD | 11 | August 24, 2021 07:40 |
Surface Roughness Drag Analysis | shindiregita | FLUENT | 0 | May 30, 2020 03:32 |
Roughness adaptation in CFX 4.4 | Bart | CFX | 1 | May 2, 2003 09:32 |
