dsmcFoam+ axissymetric simulation convergence
Old   October 13, 2023, 04:42
Default dsmcFoam+ axissymetric simulation convergence
Ashok Kumar
ashkum2527 is on a distinguished road
I am running a flow through 2D axissymmetric flow through a micro-nozzle from the throat. Throat height of the nozzle is 5mm while the exit is 21mm and length of the divergent section is 50.7mm. Total number of cells in around 1,04,000, radial extent of the domain is 0.05 and maximum radial weighting factor is 50000 (I do not know how to fix this number). nEquivalentParticles of 1e8.
Though initially the simulations are running, the number of dsmc particles are going down rapidly, and large fluctuations are seen in the average kinetic energy.
I changed the radial weigting factor to 1000 and nEquivalentParticles to 0.65e10. In both the cases, particles inserted in the domain was around 30,00,000.
But in both the cases, I am having large fluctuations in average KE and dsmc particles is going to zero.
my blockmesh file:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1e-3;
vertices
(0 0 0) //0
(5 0 0) //1
(25 0 0) //2
(50.7 0 0) //3
(100 0 0) //4
(100 20.987 0.733) //5
(100 49.969 1.744) //6
(50.7 49.969 1.744) //7
(50.7 20.987 0.733) //8
(25 11.673 0.4076) //9
(5 4.427 0.1546) //10
(0 2.498 0.0872) //11
(0 2.498 -0.0872) //12
(5 4.427 -0.1546) //13
(25 11.673 -0.4076) //14
(50.7 20.987 -0.733) //15
(50.7 49.969 -1.744) //16
(100 49.969 -1.744) //17
(100 20.987 -0.733) //18
blocks
hex (1 10 13 1 0 11 12 0) dsmcZone (120 1 240) simpleGrading (1 1 1)
hex (2 9 14 2 1 10 13 1) dsmcZone (120 1 330) simpleGrading (1 1 1)
hex (3 8 15 3 2 9 14 2) dsmcZone (120 1 120) simpleGrading (1 1 1)
hex (4 5 18 4 3 8 15 3) dsmcZone (120 1 100) simpleGrading (1 1 1)
hex (5 6 17 18 8 7 16 15) dsmcZone (100 1 100) simpleGrading (1 1 1)
edges
arc 11 12 (0 2.5 0)
arc 10 13 (5 4.43 0)
arc 9 14 (25 11.68 0)
arc 8 15 (50.7 21 0)
arc 7 16 (50.7 75 0)
arc 5 18 (200.7 21 0)
arc 6 17 (200.7 75 0)
boundary
inlet
type patch;
faces
(0 11 12 0)
outlet
type patch;
faces
(4 5 18 4)
(18 17 6 5)
(17 16 7 6)
walls
type wall;
faces
(11 10 13 12)
(10 9 14 13)
(9 8 15 14)
(8 7 16 15)
side1
type wedge;
faces
(0 1 13 12)
(1 2 14 13)
(2 3 15 14)
(3 4 18 15)
(15 18 17 16)
side2
type wedge;
faces
(0 1 10 11)
(1 2 9 10)
(2 3 8 9)
(3 4 5 8)
(8 5 6 7)
axis
type empty;
faces
(0 1 1 0)
(1 2 2 1)
(2 3 3 2)
(3 4 4 3)
mergePatchPairs
ashkum2527 is offline   Reply With Quote
axissymmetry, dsmcfoam+, openfoam, radial weighting factor, rwf
interFoam Simulation speed and convergence graph caganini OpenFOAM Running, Solving & CFD 0 April 12, 2022 04:34
indoor simulation convergence problem jhlee9622 FLUENT 0 July 3, 2017 04:44
Cyclone Simulation Convergence Problem Sal FLUENT 8 December 17, 2014 08:46
How stop simulation if convergence is not reached? Andreas FLUENT 0 October 16, 2007 13:35
convergence for an Unsteady simulation Palani Velladurai FLUENT 1 March 19, 2007 11:56
