Rep Power: 3 ![]() |
Hello Foamers,
I am working on simulating the gas behavior in the molten lead in the nuclear reactor. Even though interFoam works with incompressible fluids, I am familiar that they have implemented a compression flux to deal with the expansion of the possible gasses. This compression flux is defined through relative velocity Ur = min(C_alpha phi/Sf, max(phi/Sf)). In the OpenFOAM v10, in alphaEqn.H, no explicit equation describes this flux. I was checking src code, but since I am unfamiliar with C++ (I understand the basics), I need help understanding it. I would appreciate it if someone could shine a light on this issue. Kind regards ![]() |
compression flux, interfoam, openfoam v10 |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
