Converting a SteadyState solution to a Transient one |
October 5, 2023, 09:08 |
Rep Power: 3 |
Hello all
I have just finished running a steadystate solution and I intend to use its solution as an initial condition for a new transient solution where I deploy a scalar transport field to act as a tracer gas. However even though I swapped the ddt schemes from steady state to euler, it is still not displaying the courant number in the logs (the solution also doesn't look like it's transient). I am running simpleFoam and in parallel. I did not recompose before switching. Here's a small section of the logs Code:
Time = 0.0009 smoothSolver: Solving for Ux, Initial residual = 5.299686e-06, Final residual = 2.162227e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 4.553134e-05, Final residual = 1.709658e-06, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0002430396, Final residual = 1.114784e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.007326301, Final residual = 0.0003593539, No Iterations 2 time step continuity errors : sum local = 1.773572e-11, global = -1.730942e-12, cumulative = -1.344209e-11 smoothSolver: Solving for epsilon, Initial residual = 1.622915e-08, Final residual = 2.622095e-13, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1.132605e-07, Final residual = 2.673314e-12, No Iterations 1 ExecutionTime = 756.36 s ClockTime = 758 s scalarTransport execute: s [6] **codeConstrain** [1] **codeConstrain** [0] **codeConstrain** [5] **codeConstrain** [2] **codeConstrain** [4] **codeConstrain** [3] **codeConstrain** [9] **codeConstrain** [8] **codeConstrain** [7] **codeConstrain** smoothSolver: Solving for s, Initial residual = 4.004279e-06, Final residual = 1.686405e-09, No Iterations 1 [6] **codeConstrain** [1] **codeConstrain** [3] **codeConstrain** [2] **codeConstrain** [0] **codeConstrain** [5] **codeConstrain** [7] **codeConstrain** [8] **codeConstrain** [4] **codeConstrain** [9] **codeConstrain** smoothSolver: Solving for s, Initial residual = 2.672646e-06, Final residual = 1.257604e-09, No Iterations 1 scalarTransport write: scalar1 s Time = 0.001 smoothSolver: Solving for Ux, Initial residual = 5.265667e-06, Final residual = 2.148423e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 4.534023e-05, Final residual = 1.709122e-06, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0002395136, Final residual = 1.122452e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.009247327, Final residual = 0.0008550793, No Iterations 1 time step continuity errors : sum local = 4.22062e-11, global = 1.982301e-12, cumulative = -1.145979e-11 smoothSolver: Solving for epsilon, Initial residual = 1.625604e-08, Final residual = 2.622987e-13, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1.133583e-07, Final residual = 2.672715e-12, No Iterations 1 ExecutionTime = 834.04 s ClockTime = 836 s scalarTransport execute: s [5] **codeConstrain** [2] **codeConstrain** [9] **codeConstrain** [6] **codeConstrain** [3] **codeConstrain** [1] **codeConstrain** [4] **codeConstrain** [0] **codeConstrain** [8] **codeConstrain** [7] **codeConstrain** smoothSolver: Solving for s, Initial residual = 3.56421e-06, Final residual = 1.497856e-09, No Iterations 1 [1] **codeConstrain** [5] **codeConstrain** [6] **codeConstrain** [3] **codeConstrain** [4] **codeConstrain** [2] **codeConstrain** [9] **codeConstrain** [0] **codeConstrain** [8] **codeConstrain** [7] **codeConstrain** smoothSolver: Solving for s, Initial residual = 2.396422e-06, Final residual = 1.125167e-09, No Iterations 1 scalarTransport write: scalar1 s End |
October 5, 2023, 09:16 |
Yann
Rep Power: 29 |
simpleFoam is a steady state solver. You need to run pimpleFoam for a transient case. Cheers, Yann |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 1 | June 28, 2024 08:03 |
Time step size mismatch when loading steady-state solution in Fluent for transient an | dgnidovec | FLUENT | 5 | June 12, 2023 09:18 |
Not getting converged solution in transient simulation | Julian121 | CFX | 6 | April 27, 2019 03:00 |
Steady state solution as an initial condition for a transient problem | adnanakhtar | FLUENT | 7 | November 25, 2016 06:16 |
Slow Transient Solution | scoobysimon | FLUENT | 1 | March 21, 2014 04:19 |
