twoPhaseEulerFoam: introducing a U-field dependent transversal acceleration? |
September 29, 2023, 05:42 |
R4nd1
Hello to all of you experts. I am a n00b with OpenFOAM, having only used it for a few months; I am trying to simulate a gas-liquid flow in a curved pipe. I prefer to stay 2D for the sake of getting initial results as quickly as possible.
I am using the twoPhaseEuler -solver in a rectangular geometry where the air/water flow is along the long dimension of the pipe (Y). I was hoping that I could simplify / speed up the simulation by a simple mesh I’ve generated in with blockMesh (rather than a curved 2D pipe), and introduce the centrifugal term to the momentum equation directly as U.Y^2/radius, i.e. using the along-direction velocity vector (i.e. tangential) field to calculate the radial (along X) acceleration. I’ve read many posts here about fvOptions, but so far am unsure if fvOption could be used to introduce this acceleration term . Any hints would be greatly appreciated! |
body force inclusion, fvoptions momentum source, twophaseeuelrfoam |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
twoPhaseEulerFoam Problems | Dale | OpenFOAM Running, Solving & CFD | 19 | April 21, 2009 09:02 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Field Dependent BCs | coops | OpenFOAM Running, Solving & CFD | 0 | January 18, 2007 23:01 |
How to access acceleration of steady Euler field? | winnie | FLUENT | 0 | May 2, 2003 22:53 |
