Temperature and Velocity Limiter in rhoCentralFoam
Old   September 20, 2023, 09:16
Default Temperature and Velocity Limiter in rhoCentralFoam
Nick
cfdpester is on a distinguished road
I have included in the fvoptions file the limiter of velocity and temperature in rhoCentralFoam. It's read but not applied. I want to limit temperature and velocity to avoid the solution diverging initially. Can anyone help me?
Thanks,
Nick
limitV
    type            limitVelocity;
    active          yes;
    selectionMode   all;
    min             200;
    max             400;
limitT
    type            limitTemperature;
    active          yes;
    selectionMode   all;
    min             100;
    max             600;
cfdpester is offline   Reply With Quote
Old   September 25, 2023, 09:43
prab
aneps is on a distinguished road
Hello Nick, I am also struggling with the same issue!
I learned from different sources that rhoCentralFoam does not work with fvOptions. If one wants to use fvOptions, one has to modify the source code (rhoCentralFoam.C). I am not sure how to do it properly. I have to go through the tutorials.
In case if you find a way to limit the temperature, could you please post it here? Thanks you so much.
aneps is offline   Reply With Quote
compressible solver, divergence, limiters, rhocentralfoam, stabilization
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
