September 8, 2023, 14:57 |
Problem with force coeffs
Antonio Lau
Rep Power: 4 |
I was running a simulation of a 3d wing, with simpleFoam at a speed of 20m/s
and wanted to compare the Cd and Cl values, however the values turned out to be around a Cd of 49, which isn't accurate. I already tried using a finer mesh, but the values changed only by a small margin. But in general the results looked okay, and a also the Cl/Cd ratio. So I think it has something to do with the scaling. Anton |
drag coeffcients, lift calculation |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 12:12 |
Problem with Lift and Drag coeffs | alfonsofsm | OpenFOAM Post-Processing | 0 | August 7, 2018 14:52 |
Force Coeffs with icoFoam | VSass | OpenFOAM Post-Processing | 10 | February 5, 2016 17:26 |
Force coeffs in compressible flows | nachettito | OpenFOAM Post-Processing | 0 | August 13, 2012 07:18 |
Convergence Problem with body force driven flow | Jinfeng | FLUENT | 1 | December 9, 2009 04:54 |
