September 7, 2023, 06:09 |
interDyMFoam
Saeed Jamshidi
Rep Power: 8 |
I wanna use adaptive mesh, so when I enter Code:
mpi interDyMFoam Code:
myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D$ interDyMFoam Command 'interDyMFoam' not found, but can be installed with: sudo apt install openfoam myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D$ Code:
myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D$ mpirun interFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : interFoam Date : Sep 07 2023 Time : 13:25:49 Host : DESKTOP-TK3D7CI /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : interFoam Date : Sep 07 2023 Time : 13:25:49 Host : DESKTOP-TK3D7CI PID : 11391 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : interFoam Date : Sep 07 2023 Time : 13:25:49 Host : DESKTOP-TK3D7CI PID : 11393 PID : 11390 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : interFoam Date : Sep 07 2023 Time : 13:25:49 Host : DESKTOP-TK3D7CI PID : 11392 I/O : uncollated Case : /home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 400 Selecting dynamicFvMesh dynamicRefineFvMesh I/O : uncollated Case : /home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 400 Selecting dynamicFvMesh dynamicRefineFvMesh I/O : uncollated Case : /home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 400 Selecting dynamicFvMesh dynamicRefineFvMesh I/O : uncollated Case : /home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 400 Selecting dynamicFvMesh dynamicRefineFvMesh Detected 32 cells that are protected from refinement. Writing these to cellSet protectedCells. Detected 32 cells that are protected from refinement. Writing these to cellSet protectedCells. Detected 32 cells that are protected from refinement. Writing these to cellSet protectedCells. --> FOAM Warning : From bool Foam::IOobject::readHeader(Foam::dictionary&, Foam::Istream&) in file db/IOobject/IOobjectReadHeader.C at line 116 Reading "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D/constant/polyMesh/sets/protectedCells" at line 1 First token could not be read or is not 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class IOobject; location "constant/polyMesh/sets"; object protectedCells; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Detected 32 cells that are protected from refinement. Writing these to cellSet protectedCells. PIMPLE: Operating solver in PISO mode Reading field p_rgh PIMPLE: Operating solver in PISO mode Reading field p_rgh PIMPLE: Operating solver in PISO mode Reading field p_rgh PIMPLE: Operating solver in PISO mode Reading field p_rgh --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) cannot find file "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D/400/p_rgh" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 542. FOAM exiting --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) cannot find file "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D/400/p_rgh" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 542. FOAM exiting --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) cannot find file "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D/400/p_rgh" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 542. FOAM exiting --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) cannot find file "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder3D/400/p_rgh" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 542. FOAM exiting ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[17335,1],0] Exit code: 1 -------------------------------------------------------------------------- thank you |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 05:19 |
Restart InterDymFoam simulation from latestTime | Giovanni_Do | OpenFOAM Running, Solving & CFD | 2 | April 11, 2019 05:22 |
Standard InterDyMFoam doesn't work after modifying interFoam | nesca87 | OpenFOAM Running, Solving & CFD | 7 | January 5, 2017 22:47 |
modifying interDyMFoam for floatingObject | Elisabeth_ofoam | OpenFOAM Programming & Development | 7 | June 11, 2014 08:42 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
