overInterDymFoam - How to define dynamicMeshDict for an attenuator type device |
September 6, 2023, 09:13 |
Nian
Rep Power: 7 |
Hello everyone,
I've been trying to build a case for simulating wave interaction with an attenuator-type wave energy converter device, and I want to set the case up as shown in Figure 1. where the 2 box bodies are allowed to freely rotate around the hinge in the middle as waves pass through, and the hinge is free to move vertically (in the future potentially considering to add mooring to the geometry and allow the hinge to move freely). I have currently set the dynamicMeshDict as follows, where I have applied joints to move freely in Y and Z, and rotate about Y axis (I think). I've also set with the transform keyword for the centre of rotation to be at the origin initially (0 0 0). Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // motionSolverLibs ("librigidBodyMeshMotion.so"); dynamicFvMesh dynamicOversetFvMesh; dynamicOversetFvMeshCoeffs { } motionSolver rigidBodyMotion; // rigidBodyMotionCoeffs - not needed any more // { report on; solver { type Newmark; // gamma 0.1; // Velocity integration coefficient // beta 0.1; // Position integration coefficient } accelerationRelaxation 0.7; //- prescribedRotation requires some sub-iterations to converge faster // to desired value. // nIter 3; bodies { box1 { type rigidBody; parent root; patches (box1); innerDistance 100; outerDistance 101; centreOfMass (-20 0 0); // Cuboid dimensions Lx 40; Ly 4; Lz 4; // Density of the solid rhoSolid 500; // Cuboid mass mass #calc "$rhoSolid*$Lx*$Ly*$Lz"; inertia (1 0 0 1 0 1); transform (1 0 0 0 1 0 0 0 1) (0 0 0); joint { type composite; joints ( { type Px; } { type Pz; } { type Ry; } ); } constraints { fixedAxis { sixDoFRigidBodyMotionConstraint plane; normal (0 1 0); // constrained in y plane? } } restraints { AngularDamper { sixDoFRigidBodyMotionRestraint sphericalAngularDamper; coeff 5000; //angular damping coefficient in Nms/rad } } } //end box1 box2 { type rigidBody; parent root; patches (box2); innerDistance 100; // With overset we want to avoid the mesh outerDistance 101; // deformation so have large innerDistance // Cuboid mass -- very simple setup. For more complicated shapes // see utility surfaceInertia // Cuboid dimensions Lx 40; Ly 4; Lz 4; // Density of the solid rhoSolid 500; // Cuboid mass mass #calc "$rhoSolid*$Lx*$Ly*$Lz"; inertia (1 0 0 1 0 1); centreOfMass (20 0 0); // relative to the centreOfMass // of parent body // (here root = global coord system) // Transformation tensor and centre of rotation transform (1 0 0 0 1 0 0 0 1) (0 0 0); joint { type composite; joints ( { type Px; } { type Pz; } { type Ry; } ); } constraints { fixedAxis { sixDoFRigidBodyMotionConstraint plane; normal (0 1 0); // constrained in y plane? } } restraints { AngularDamper { sixDoFRigidBodyMotionRestraint sphericalAngularDamper; coeff 5000; //angular damping coefficient in Nms/rad } } } // end body_Aft } // } // end of rigidBodyMotionCoeffs // ************************************************************************* // In an initial trial run, the results at around 4s show the Centre of Rotation shifting to -85 m in Z which seems unphysical (or maybe I've interpreted it wrongly?): Code:
Rigid-body motion of the fwd Centre of rotation: (0 0 -85.1395255871) Orientation: (1 0 0 0 1 0 0 0 1) Linear velocity: (0 0 -40.8709835732) Angular velocity: (0 0 0) Rigid-body motion of the aft Centre of rotation: (0 0 -85.1395255871) Orientation: (1 0 0 0 1 0 0 0 1) Linear velocity: (0 0 -40.8709835732) Angular velocity: (0 0 0) inverseDistance : detected 2 mesh regions zone:0 nCells:9576000 voxels:(85 85 85) bb:(-90.0000603573 -12.0000603573 -20.0000603573) (-34.0180396427 0.147119357345 -0.987181642655) zone:1 nCells:5615950 voxels:(85 85 85) bb:(-40.0000076955 -4.00000769553 -4.00000769553) (-34.0998923045 7.85500095484e-06 -1.09999230447) Overset analysis : nCells : 15191950 calculated : 14708262 interpolated : 250840 (interpolated from local:236708 mixed local/remote:14126 remote:6) hole : 232848 Thanks, everyone! |
dynamicoverset, hinge motion, overinterdymfoam, overset, rigid body motion |
Hydrogen storage by metal hydride | longbk | FLUENT | 12 | August 1, 2023 20:13 |
UDF for tracking interface in 2 phase VOF method. | Cooper24 | Fluent UDF and Scheme Programming | 16 | October 26, 2021 05:42 |
An odd ERROR | mdakbari | Fluent UDF and Scheme Programming | 7 | April 4, 2016 04:30 |
udf-Surface Reaction Rate-parse error in line 34 | priya_1985 | FLUENT | 1 | November 10, 2014 02:48 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
