Droplet Impact on a solid surface using interFoam |
August 27, 2023, 10:35 |
Yaminul Hoque
Hi. I was trying to simulate water droplet impact on a solid surface using interFoam. But the results are different from experiment since some secondary droplets are produced. Similar results were seen on a thesis by Fei Gao where she mentioned that this is because the interface between air and water isn't fine enough.(attached in picture). Is there a good way to solve this problem ? Shall I use dynamic mesh to solve this ?
DeltaT keeps decreasing after droplet impact on the surface. | chichi1228 | OpenFOAM Running, Solving & CFD | 2 | April 14, 2021 04:07 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Help!! customize surface tension term in interFoam | w051cxw | OpenFOAM Running, Solving & CFD | 0 | February 12, 2016 01:15 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
