Pressure gradient slow and continuously growup
Old   August 23, 2023, 18:12
Default Pressure gradient slow and continuously growup
Abel Bonfil Garcia
Abonfil04 is on a distinguished road
Hi, foamers , i'm relatively new in OpenFoam
i'm trying to simulate a centrifugal pump but i'm facing some problems with the pressure grandient, due to it continously grow whitout stopping.
I already try
- fvSchemes modifications
- fvSolutions modifications
- bc's modifications like:
-totalPressure at inlet and flowrate at outlet
-flowrate at inlet and static pressure at outlet
This case is steady-state, i'm using frozen rotor and komegasst
Pump parameters:
- 3600 rpm
- capacity of 608 l/min
- total head of 77.8 m
here some files of my simulation:
U:
boundaryField
    Inlet
        type                     flowRateInletVelocity;
        volumetricFlowRate       uniform 0.010133333;
        value                    uniform (0.0 0.01013 0.0);
    Outlet
        type                        inletOutlet;
        inletValue                  uniform (0 0 0);
        value                       uniform (0 0.01013 0);
    "(Wall_1|Wall_2|Wall_3|Wall_4)"
        type            noSlip;
    "(AMI1_2|AMI2_2|AMI3_2|AMI3_1|AMI2_1|AMI1_1)"
        type            cyclicAMI;
p:
boundaryField
    Inlet
        type            zeroGradient;
        // outletValue     uniform 0;
        value           uniform 0;
    Outlet
        type            fixedValue;
        value           uniform 101.325;
        type            zeroGradient;
		type			cyclicAMI;
fvSchemes:
ddtSchemes      // unmodifiable
    default         steadyState;
gradSchemes
    default cellMDLimited Gauss linear 0.5;
    grad(U) cellMDLimited Gauss linear 1.0;
divSchemes
    default                         none;
    div(phi,U)                      Gauss linearUpwind grad(U);
    div(phi,k)                      Gauss upwind;
    div(phi,omega)                  Gauss upwind;
    div((nuEff*dev2(T(grad(U)))))   Gauss linear;
    div(R)                          Gauss linear;
    div(phi,R)                      bounded Gauss limitedLinear 1;
laplacianSchemes
    default         Gauss linear limited 0.5;
snGradSchemes
    default         limited 0.5;
interpolationSchemes
    default         linear;
wallDist
    method meshWave;
fvSolution:
solvers
    p
        solver                      GAMG;
        tolerance                   1e-8;
        relTol                      0.01;
        smoother                    GaussSeidel;
        nCellsInCoarsestLevel       1;
        minIter                     4;
        maxIter                     100;
    U
        solver          PBiCGStab;
        preconditioner  DILU;
        // nSweeps         2;
        tolerance       1e-8;
        relTol          0.0;
        minIter         4;
        maxIter         100;
    k
        solver          PBiCGStab;
        // nSweeps         2;
        tolerance       1e-8;
        relTol          0.0;
        minIter         4;
        maxIter         100;
    omega
        solver          PBiCGStab;
        // nSweeps         2;
        tolerance       1e-8;
        relTol          0.0;
        minIter         4;
        maxIter         100;
SIMPLE
    nNonOrthogonalCorrectors 2;
    pRefCell                 0;
    pRefValue                0;
    residualControl
            p                   1e-4;
            U                   1e-4;
            "(k|omega|epsilon)" 1e-4;
relaxationFactors
    fields
        p               0.3;
    equations
        default         0.9;
        U               0.5;
        k               0.9;
        omega           0.9;
        epsilon         0.9;
i will apreciate any comment and help
thanks
Abonfil04 is offline   Reply With Quote
Old   October 20, 2023, 10:56
Pedro Gouveia
unilord is on a distinguished road
Hey,
Have you already found an answer to your problem? I am currently working in a centrifugal pump and the residuals I am getting are really close to yours.
unilord is offline   Reply With Quote
centrifugal pump, incompressible flow, openfaom
