wedge mesh running sigfpe error with exploding values |
Song Young Ik
Rep Power: 4 ![]() |
I made a wedge mesh using salome and converted to openfoam using unv, and ran a test case.
Then, it showed such sigFpe error, exploding velocity values over 1e35 I also made full 3d mesh which is same geometry as revolved wedge mesh, and it worked fine. Therefore it seems like problem to mesh, not solver setting. Wedge was rotated 5 degree, and form shape of nozzle. It isn't single layer wedge, and mainly tetrahedral due to salome setting and ease for converting What could be the solution? Wedge is already 5 degree so increasing angle seems impractical... Code:
[9] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [9] #1 Foam::sigFpe::sigHandler(int) at ??:? [9] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [9] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [9] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [9] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [9] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [9] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/simpleFoam" [9] #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/simpleFoam" [9] #9 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/simpleFoam" [9] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [9] #11 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/simpleFoam" [openfoam:308243] *** Process received signal *** [openfoam:308243] Signal: Floating point exception (8) [openfoam:308243] Signal code: (-6) [openfoam:308243] Failing at address: 0x3e80004b413 [openfoam:308243] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7fe5f6c92090] [openfoam:308243] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7fe5f6c9200b] [openfoam:308243] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7fe5f6c92090] [openfoam:308243] [ 3] /opt/openfoam10/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0x260)[0x7fe5f76c9bb0] [openfoam:308243] [ 4] /opt/openfoam10/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x85d)[0x7fe5f76cda7d] |
Rep Power: 14 ![]() |
What does checkMesh say? Is it happy with the mesh?
Song Young Ik
Yes checkmesh is good...
gamg, nozzle, salome, sigfpe, wedge |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
