Problem with Solving a Test case of Supersonic Combustion / Cold Flow |
Sasi Kiran
Rep Power: 0 ![]() |
Hi everyone,
Greetings. I am trying to simulate a cold flow (no combustion) test case on a step mixer geometry for supersonic flow visualisation using rhoCentralFoam. I have tried different ways by changing the fvScheme and boundary patch names. but the flow is not passing across the combustor. it just reached the step and the simulations getting stopped with an error message appearing as " FOAM FATAL ERROR: Negative initial temperatures" Kindly, please let me know, where could be the error, and what can be the reason. how to approach.. ! Thank you very much in advance..! Please find the case file. Expected result vs my result link for the case file: https://drive.google.com/file/d/1Ca-...ew?usp=sharing my result.jpg Expected result.jpg |
Sasi Kiran
Note, I have tried with OpenFOAM 7 version.
mixing, openfoam, scramjet, shockwave, supersonic flow |
rhoSimpleFoam High Pressure Cell Crashes Simulation | NorthCFD | OpenFOAM Running, Solving & CFD | 0 | March 3, 2023 05:02 |
Help sought on axial compressor simulation | jyotir | OpenFOAM Running, Solving & CFD | 0 | November 17, 2021 10:49 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
