Why isn't the Kunz model in OpenFOAM 3-phase following the 20O0 reference paper? |
August 14, 2023, 05:32 |
spacecat
I was reading the OpenFOAM cavitation Kunz model reference paper and if I did not misunderstand, the paper talks about 3-phase flow (liquid, vapor, and non-condensable gas). Yet, when I looked at the modelled equations in the solver code in OpenFOAM v10 for the Kunz model it seems to be 2-phase flow. Is there a reason why OpenFOAM does not employ the 3-phase flow Kunz model? Thank you very much in advance! |
August 20, 2023, 07:02 |
Humberto
Rep Power: 5 |
I don't know that article, but in the whole HEM formulation, it assumes a non-condensable gas. However, when a non-condensable gas is present, it slows down cavitation. Additionally, for stability, it's often assumed that the pressure of the non-condensable gas is equal to the gas pressure. Maybe OpenFoam assumes that within a certain pressure range, all the gas can cavitate without the influence of another phase.
3-phase, cavitation, kunz |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
Recommendation of paper for Reynolds Stress Model | FluidKo | Main CFD Forum | 7 | February 10, 2022 08:57 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 09:38 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
