Non-zero exit code in openFoam
Old   August 14, 2023, 02:40
Default Non-zero exit code in openFoam
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hello, i have faced with the below error after using snappyHexMesh in my simulation. Would you please tell me how i could solve it?
Thanks.
.................................................. ....this is a part of error.....................
Time = 2.4
PIMPLE: iteration 1
time step continuity errors : sum local = 1.205980541660089e-07, global = -2.992993386348176e-08, cumulative = -1.980465916623756e-06
ExecutionTime = 39.1 s ClockTime = 39 s
forceCoeffs forces execute:
Coefficients
Cd : 0.000520627699235436 (pressure: 0.0005174975751252223 viscous: 3.13012411021369e-06)
Cs : 6.691920704468332e-08 (pressure: 2.221506120002125e-07 viscous: -1.552314049555291e-07)
Cl : 7.495368832353548e-05 (pressure: 8.194528580102265e-05 viscous: -6.991597477487161e-06)
CmRoll : -4.940700138732516e-07 (pressure: -5.483547355406437e-07 viscous: 5.428472166739212e-08)
CmPitch : -3.762127447378717e-05 (pressure: -4.096953928460914e-05 viscous: 3.348264810821962e-06)
CmYaw : 3.55335482906227e-06 (pressure: 3.604684895546287e-06 viscous: -5.133006648401698e-08)
Cd(f) : 0.0002598197796038448
Cd(r) : 0.0002608079196315913
Cs(f) : 3.586814432584612e-06
Cs(r) : -3.519895225539928e-06
Cl(f) : -1.444303120194332e-07
Cl(r) : 7.509811863555492e-05
Courant Number mean: 0.05635565378975434 max: 98057.73052293921
Time = 2.4
PIMPLE: iteration 1
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[25529,1],0]
Exit code: 145
myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D$
saeed jamshidi is offline   Reply With Quote
error
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
OpenFOAM, progress in academia and industry, after 13 years' effort sharonyue OpenFOAM 5 March 29, 2018 13:09
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
Specific OpenFOAM Code pbhuter OpenFOAM 13 June 30, 2012 20:06
