Awan
Rep Power: 0 ![]() |
![]() I had tried alot to run the tutorials of dsmcfoam using already available case but everytime error pops out when i run the command dsmcFoam. blockMesh and dsmcInitialise command runs properly but following error pops out while running "dsmcFoam". kindly tell what is the reason behind that. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Constructing dsmcCloud --> FOAM FATAL ERROR: (openfoam-2306) cannot find file "C:/Users/Rashid/AppData/Roaming/ESI-OpenCFD/OpenFOAM/v2306/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2306/tutorials_copy/discretemethods/dsmcfoam/freeSpacePeriodic/0/q" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 627. FOAM exiting |
Yann
Rep Power: 27 ![]() |
The solver complains about a missing file for the q variable in the 0 directory: Code:
--> FOAM FATAL ERROR: (openfoam-2306) cannot find file "C:/Users/Rashid/AppData/Roaming/ESI-OpenCFD/OpenFOAM/v2306/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2306/tutorials_copy/discretemethods/dsmcfoam/freeSpacePeriodic/0/q" I never used dsmcFoam so I have no idea what is the q variable but you can check dsmcFoam tutorials. Regards, Yann |
dsmcfoam, foam warning error, openfoam |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
