August 4, 2023, 16:37 |
interpolation issues with overset meshes.
Rithwik Kandukuri
Rep Power: 3 |
Hey. Ive been trying to implement a 2d vawt case using overset meshes. Ive been having issues with the interpolation at the fringe. Looking at the velocity field, I see some timesteps with a noticeable interpolation error between the background and the component meshes. I suspect this is because the field values are changing a lot near the interpolation fringe ( and that is generally not recommended?). I cant make the component meshes much larger to prevent this issue because then the component mesh goes outside the background mesh region. I attached photos of the component vs background mesh so you all could check if the mesh resolution is the one that's causing the issue. That is one thing I need help with. Secondly, the pressure field is all over the place: spurious oscillations and unresolved features. Could someone go over my case files and see if am making any mistakes while setting up the case/ better controls?
https://mega.nz/file/gOoBzJ5b#dufDWw...4iFlMRtzw-3rSk |
overpimpledymfoam, overset, oversetinterpolation, oversetmesh |
Inlet Profile Interpolation | dwstevens | SU2 | 1 | April 18, 2020 10:10 |
GGI interpolation issues with foam-extend3.2 | BiomechanicsBath | OpenFOAM Running, Solving & CFD | 3 | September 21, 2019 02:26 |
Post Processing Issues with Overset Mesh | jtguerra | STAR-CCM+ | 0 | October 3, 2018 04:33 |
Overset MESH problem DFBI 6DOF | Ale85 | STAR-CCM+ | 0 | October 1, 2013 13:25 |
Issues with tetrahedral tetra meshes | billy | OpenFOAM Running, Solving & CFD | 0 | May 8, 2006 19:03 |
