August 4, 2023, 10:18 |
Pimplefoam residual zero?
Aran
Rep Power: 3 |
Hi, I am trying to run a case with a dynamic mesh of an impeller in a tank. I have created a case that works with MRF and SIMPLE but for some reason, it doesn't work in dynamic mesh and PIMPLE. I have created a cylinder cellzone around the impeller that is supposed to move when told to in the dynamicmesh file and have used createbaffles to establish a cyclic condition between the connected faces of the moving and non moving mesh. When I run pimplefoam, I just get that the courant number is 0, residuals and values for p and U are zero. What is going wrong here?
dynamic, pimple |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
