Choose an internal boundary as a faceset?
Old   July 28, 2023, 09:55
Unhappy Choose an internal boundary as a faceset?
Aran
Aran55336 is on a distinguished road
I have created a volume mesh of a tank with an impeller carved out in gmsh and have chosen the internal boundary of the impeller and the outer boundary of the tank as physical surfaces in gmsh. I am trying to use topoSet to define a faceset and cellset so that I can make the impeller rotate, how can I do this?
Aran55336 is offline   Reply With Quote
mrf, openfoam, rotate, toposet
Boundary condition for Internal Baffle shanvach OpenFOAM Running, Solving & CFD 3 December 29, 2023 03:32
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
