setFields dict not working properly with Pointwise mesh |
July 27, 2023, 17:45 |
Rep Power: 5 |
Hello.
I'm facing a weird problem. I am trying to simulate a two phase flow around tandem cylinders and setFields utility cannot set the domain between (-0.025 < z < 0) to alpha.1=1. It generates random field. I assume the numbering of the mesh is wrong somewhere. Any ideas how to fix this? Code:
defaultFieldValues ( volScalarFieldValue alpha.1 0 ); regions ( boxToCell { box (-1.5 -1 -0.025) (1.5 1 0); fieldValues ( volScalarFieldValue alpha.1 1 ); } ); Code:
Checking geometry... Overall domain bounding box (-1.5 -1 -0.025) (1.5 1 0) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.76656e-15 2.6662e-15 4.39426e-15) OK. Max cell openness = 3.4972e-16 OK. Max aspect ratio = 49.1753 OK. Minimum face area = 9.05366e-08. Maximum face area = 0.000120445. Face area magnitudes OK. Min volume = 6.33756e-11. Max volume = 7.73568e-07. Total volume = 2.61402. Cell volumes OK. Mesh non-orthogonality Max: 59.85 average: 10.4086 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.980032 OK. Coupled point location match (average 0) OK. Mesh OK. Thanks. Last edited by Legacy; July 27, 2023 at 18:06. Reason: Added checkMesh results |
openfoam 2112, setfielddict |
Dynamic gradient mesh adaption not working properly | MarkelRF | FLUENT | 0 | August 28, 2018 05:19 |
[ICEM] Replay not working properly - Creating the mesh for Free Block. | Wingman | ANSYS Meshing & Geometry | 4 | January 17, 2017 03:57 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
