Why is the 'lagrangian' folder not output for small particle size?
Old   July 21, 2023, 15:05
Default Why is the 'lagrangian' folder not output for small particle size?
Fanchao Meng
Fanchao is on a distinguished road
I successfully simulated particle transport using the reactingParcelFoam solver in OpenFOAM v1912. The parcels were injected using the manual injection method, and each parcel contained only one particle. The particle size (diameter) was fixed at 1e-6 m.
However, when I attempted to change the particle size to be lower or equal to 0.7e-6 m, the 'lagrangian' folder disappeared. This folder contains important information for each particle, such as particle ID, position, velocity, temperature, etc.
Does anyone know how to configure the simulation to output the 'lagrangian' folder even for small particle sizes? Any assistance would be greatly appreciated.
Fanchao is offline   Reply With Quote
Old   August 3, 2023, 05:26
oswald is on a distinguished road
Are you sure that your particles are still in the domain at write time? Maybe they just evaporated or fell below a limit, e.g. for minParcelMass. You can try to change or add the latter in your cloud's constantProperties. It might be set to 1e-15 as a default, which could be in the range of your particles' mass.
oswald is offline   Reply With Quote
lagrangian, reactingparcelfoam, small particle
output lagrangian particle volume fraction "reactingParcelFoam" bijan darbari OpenFOAM Programming & Development 20 February 12, 2022 23:15
Assign Particle Size in java for Polyhedral Partcles Vee STAR-CCM+ 1 April 22, 2018 10:45
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 17:30
Request for Lagrangian Particle Tracking Validation or Verification Paper Mojtaba.a OpenFOAM Verification & Validation 6 May 23, 2016 02:47
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
