Boundary condtions difference between fluid and slurry
Old   July 17, 2023, 05:28
Default Boundary condtions difference between fluid and slurry
Turhan
Turhan is on a distinguished road
Hi all,
I have a semi submerged pipe inside water. It has two outlets, one is inside the water and has hydrostatic pressure and the other one is outside the water and has atmospheric pressure. I calculated these values and filled them in as fixedValues in the boundary conditions.
When simulating this as pure fluid I have no issue and the simulation looks correct.
However, when I add particles through DPMFoam the velocity seems to have jumps, which is caused by the pressure having big jumps in its value.
I was wondering what effects particles add (such as higher density, additional friction losses, etc) that I need to take into consideration when determining the boundary conditions. And why is my simulation not correct anymore? The hydrostatic pressure outside the pipe does not change after all, so should I really be changing the boundary condition?
Turhan is offline   Reply With Quote
dpmfoam, lagrange, lagrangian, pressure boundaries, slurry flow
Pipe Annulus Flow of slurry: solids (cuttings) with power law Non-Newtonian fluid foued.badrouchi FLUENT 0 August 4, 2019 18:33
Highly viscous (500 Pa.s) fluid flow ahmadijaz Fluent Multiphase 2 June 5, 2019 09:52
