Problem with "variableHeightFlowRateInletVelocity" BC and Tetrahedral Mesh-interFoaM
Old   July 13, 2023, 07:02
Default Problem with "variableHeightFlowRateInletVelocity" BC and Tetrahedral Mesh-interFoaM
KGN
mecbe2002 is on a distinguished road
Hi all,
I am trying to simulate open channel flow with variable height inlet (based on intet flow rate the water level will change) boundary condition using interFoam. The simulation runs fine with HEX mesh; but with TET mesh the alpha.water plot is weird at inlet.
I cannot share the actual geometry, so I ran the simulation with simple open channel bend with same simulation setup for both HEX and TET mesh. I have attached the plots and solver setup.
Please let me know what is the issue with the problem setup?
Boundary Condition - U
inlet - variableHeightFlowRateInletVelocity
outlet - pressureInletOutletVelocity
wall - noSlip
atmosphere - pressureInletOutletVelocity
Boundary Condition - p_rgh
inlet - zeroGradient
outlet - prghTotalPressure
wall - fixedFluxPressure
atmosphere - prghTotalPressure
Boundary Condition - k
inlet - fixedValue
outlet - inletOutlet
wall - kqRWallFunction
atmosphere - inletOutlet
Boundary Condition - epsilon
inlet - fixedValue
wall - epsilonWallFunction
Boundary Condition - alpha.water
wall - inletOutlet
atmosphere - zeroGradient
ddtSchemes
    default         Euler;
gradSchemes
    default         cellLimited Gauss linear 1;
divSchemes
    div(rhoPhi,U)  Gauss upwind;//linearUpwind grad(U);
    div(phi,alpha)  Gauss PLIC interfaceCompression vanLeer 1; //vanLeer;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    5;
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0.0;
    "pcorr.*"
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-6;
        relTol           0.0;
    p_rgh
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-6;
        relTol           0.0;
    p_rghFinal
        $p_rgh;
        tolerance       1e-6;
        relTol          0;
    "(U|k|epsilon)"
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0.0;
    "(U|k|epsilon)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors  1;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    /**equations
        ".*" 1;
    equations
        "U.*"                       0.7;
        "p.*"                       0.7;
        "(k|epsilon).*"             0.7;
        "alpha.water.*"             0.7;
Initial Condition : Attachment 95362
Hex Mesh result : Attachment 95363
Tet Mesh result : Attachment 95364
mecbe2002 is offline   Reply With Quote
