backwardDual time stepping in foam extend
Old   July 13, 2023, 06:24
Default backwardDual time stepping in foam extend
Bidesh Sengupta
BSengupta is on a distinguished road
Hi!
I am trying to run the time stepping by backwardDual scheme for dbns solvers (dbnsTurbFoam) and I am using the syntax in fvSchemes as:
ddtSchemes
    default         backwardDual physDeltaT CoDeltaT;
The error that I am receiving is:
--> FOAM FATAL ERROR:
    request for volScalarField rhoOld from objectRegistry region0 failed
    available objects of type volScalarField are
14
div(phi)
psi
h
rho
k
psi_0
alphat
alpha
p
T
rhoE
mut
mu
epsilon
Can anyone give me some suggestion how to run backwardDual time stepping?
Thank you,
Bidesh
BSengupta is offline   Reply With Quote
foam extend 4.1, holzmann cfd, jasak, open foam, time step
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
