Specify transport properties using function2 object in OpenFoam |
Harish Gopal
Rep Power: 3 ![]() |
Hi All,
I hope you are having a great day ! For my research, I am computing the response of laminar premixed flames to acoustic forcing. I am then changing various fuels to see the effect of different fuels on the flame dynamics. For computing the diffusive mass and energy fluxes, I am using the Fickian model where one needs to specify the binary or mixture averaged diffusion coefficients. The binary diffusion coefficients can be extracted from literature or CHEMKIN or Cantera, where they are written down in terms of a polynomial expansion. In other words, ln(D_ij) = A_0 + A_1 ln(T) + A_2 ln(T)^2 + ... My question is how do I specify this in Openfoam. In the Fickian.H file the following is written: "The mixture diffusion coefficients are specified as Function2<scalar>s of pressure and temperature but independent of composition." Please, can anyone instruct me how to use this Function2<scalar> object. More specifically, how do I instruct OpenFoam to know that D_ij will be of the above form in terms of temperature. Any suggestions would be great please. Thanks, Harish. |
JuanMi
Rep Power: 8 ![]() |
All you need to understand Function2 is here:
https://github.com/OpenFOAM/OpenFOAM...ions/Function2 Function2 is a template class which admit 2 arguments and return 1. The logic behind is programmed in its derived classes. In OF case, the mixture diffusion parameters depend on that, pressure and temperature, and for that reason is a Function2. If you have an expression for that relationship, and it only depends on the temperature, I would use the coded version. Only you need is, in the thermophysicalTransport dictionary, introduce that relationship when you define the variable Dm, for example. The use of coded would be something similar to this: Coded boundary condition To begin, try to mimic other Function2 as this: https://github.com/OpenFOAM/OpenFOAM...nt/Constant2.H |
Harish Gopal
Hi JuanMi,
Super ! Thanks a lot for your quick response. Yes, you right, the coded function object seems to be the best option. However, I was not very confident of my coding skills ![]() OH-H { type uniformTable; low (91192.5 200.0); high (151987.5 3000.0); values 10 20 ( (9.376082804843815e-05 0.00025530938139315393 0.00047145082144682174 0.0007348424533524699 0.0010410077644183143 0.0013868237506628248 0.0017699361503138813 0.002188478205786576 0.002640916115086698 0.0031259559832085212 0.003642483925028823 0.004189525479741268 0.004766216970381311 0.005371784614578548 0.0060055288661967346 0.006666812404327898 0.0073550507369047535 0.008069704723696992 0.00881027453768912 0.009576294724034665 ) (8.72945640450976e-05 0.0002377018378487985 0.00043893697169186853 0.0006841636634660926 0.0009692141254929134 0.0012911807333757335 0.001647871588223269 0.002037548674353019 0.0024587839692186498 0.002910372811952761 0.0033912781370958006 0.0039005926880349736 0.004437512351734324 0.005001316710124855 0.005591354461631442 0.006207032238512181 0.006847805858497529 0.007513173363442027 0.008202669397158836 0.008915860605135722 ) (8.166265668734935e-05 0.0002223662354069405 0.0004106184573891673 0.0006400240722747318 0.0009066841819127253 0.0012078787505772988 0.0015415572922088641 0.001906093921168953 0.0023001527453980915 0.0027226068240848405 0.003172485999218652 0.0036489415468714263 0.004151221232267593 0.004678651115923251 0.005230621915719736 0.005806578545704943 0.006406011932142849 0.007028452501284476 0.007673464919922781 0.008340643791901158 ) (7.671340476690394e-05 0.0002088894938671259 0.0003857324902746723 0.0006012347345611117 0.0008517336254331662 0.0011346739778150382 0.001448129577529539 0.0017905730774617436 0.002160749548707298 0.002557600349897881 0.0029802141204781276 0.0034277935743337643 0.0038996320666756174 0.004395096502836994 0.004913614526888236 0.005454664694450098 0.0060177687847402525 0.006602485683024811 0.007208406439927461 0.007835150228755633 ) (7.232978163736657e-05 0.000196952951360433 0.0003636906336875482 0.0005668784640147624 0.000803063132551271 0.0010698354647970362 0.0013653793159564226 0.0016882546158925012 0.0020372781459240237 0.0024114517584751445 0.0028099161707365204 0.0032319196558004064 0.003676795948579868 0.004143948131246308 0.004632836553923194 0.005142969569052949 0.005673896282755095 0.006225200786851965 0.006796497500503034 0.007387427358541026 ) (6.842006371102243e-05 0.0001863068458814907 0.00034403168051524833 0.0005362363848788294 0.0007596543145755267 0.0010120065207539532 0.0012915750286074269 0.0015969976096280418 0.001927155002901104 0.002281103014773786 0.002658028810156168 0.0030572212960274115 0.003478050221629605 0.003919950934962725 0.004382412956413833 0.004864971213969007 0.005367199186389955 0.00588870344702213 0.006429119257232601 0.006988106960782053 ) (6.491134249507257e-05 0.00017675264865679886 0.00032638903023241505 0.0005087370830901715 0.000720697683058833 0.0009601087504588787 0.001225340411755764 0.0015151002963137833 0.001828326541213868 0.0021641233729905148 0.0025217196404045696 0.0029004407167439548 0.003299688671802446 0.0037189278100928412 0.004157673830443893 0.004615485510688544 0.005091958202472522 0.005586718654867148 0.006099420833784775 0.006629742501254768 ) (6.174493554409342e-05 0.000168130568234516 0.0003104676141235168 0.0004839206400126021 0.0006855416985193778 0.0009132741772657627 0.0011655677087432877 0.0014411929647862817 0.0017391398806668498 0.002058556379186099 0.0023987089262384933 0.0027589558037320544 0.0031387282487876926 0.0035375166974053853 0.003954860472861264 0.004390339876020811 0.004843569997473862 0.005314195793654117 0.005801888110185518 0.006306340428022828 ) (5.887307807692628e-05 0.00016031054180500363 0.00029602725997823694 0.00046141270326782995 0.0006536560381231277 0.0008707963085557272 0.0011113552571738324 0.0013741607338659894 0.0016582496536590894 0.001962809570851862 0.0022871410692041445 0.0026306322779770753 0.0029927408883789627 0.003372981037060949 0.0037709134741235307 0.004186138021322169 0.004618287672009962 0.005067023896274856 0.005532032849246657 0.0060130222685799055 ) (5.6256496829062894e-05 0.00015318562883589237 0.0002828704928680931 0.00044090547201148194 0.0006246046586509886 0.0008320942503976949 0.0010619616901883287 0.0013130869234719456 0.0015845496690520188 0.0018755735899251128 0.0021854903550172938 0.0025137152878447607 0.0028597301822287867 0.003223070768747129 0.0036033173197180406 0.004000087442596739 0.004413030442142852 0.004841822834218195 0.005286164722613472 0.005745776834420799 ) ); } In the above, I have specified the binary diffusion coefficient for the species pair OH-H in terms of the two dimensional table as a function of pressure and temperature. The pressure varies along the row, while the temperature varies along the column. The low and high values signify the Hope this helps you and all others. Thanks and have a nice day ! Harish |
Rep Power: 0 ![]() |
Hi Harish,
Can you please verify whether or not your method works as expected? |
Simulation DNS for two phase flow in openFoam | ht2017 | OpenFOAM Running, Solving & CFD | 0 | December 8, 2020 05:50 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
