Partially frozen flow in chtMultiRegionFoam
Old   June 30, 2023, 08:23
Default Partially frozen flow in chtMultiRegionFoam
BastiL
bastil is on a distinguished road
Hello all,
I have to solve some heat transfer cases that are softly coupled, e.g. there is a more or less steady flow field and a transient temperature distribution. I tend to run this with the frozenFlow flag turned on in chtMultRegionFoam and using a fixed/fozen flow field. This turns calculation time from months into hours for my problems.
However, as there is some effect in flow field by thermal distribution (e.g. density changes) I am looking for a way to solve the fluid flow from time to time (every 2,5,10,20,...time step for example). Is there any straingthforward way to do this out of the box or does it require me to modify chtMultiRegionFoam? Thanks.
Best regards
BastiL
bastil is offline   Reply With Quote
chtMultiRegionFoam simple pipe flow TomS OpenFOAM Running, Solving & CFD 1 May 12, 2023 06:24
Order of FFT and using Taylor's Frozen Flow Hypothesis for Grid Turbulence Matter? loesung Main CFD Forum 1 March 31, 2022 09:56
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
chtMultiRegionFoam - exchange data between flow field and temperature phsieh2005 OpenFOAM Running, Solving & CFD 0 February 7, 2012 10:16
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
