Capillary flow in open rectangular microchannel
Old   June 27, 2023, 03:09
Default Capillary flow in open rectangular microchannel
Gaurav Kumar
kumar.kyutech is on a distinguished road
I am trying to simulate capillary flow in a 3D open rectangular microchannel using interFoam. I modified the capillary rise tutorial example to make it for an open channel.
After I run the simulation, the results don't look correct. The fluid is not moving and the free surface is not visible.
Nomenclature:
wallss - open surface
wall - microchannel walls
Can anyone help identify the problem?
Here is my source code:
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type inletOutlet;
value uniform 1;
inletValue uniform 1;
atmosphere
type zeroGradient;
walls
type constantAlphaContactAngle;
theta0 30;
limit gradient;
value uniform 0;
wallss
type inletOutlet;
inletValue uniform 0;
value uniform 0;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0;
atmosphere
type fixedValue;
value uniform 0;
walls
type fixedFluxPressure;
wallss
type totalPressure;
p0 uniform 0;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
atmosphere
walls
type noSlip;
wallss
defaultFaces
type empty;
kumar.kyutech is offline   Reply With Quote
free surface flow, interface bc, interfoam surface tension, micro channel, open channel flow
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
