interDyMFoam-FoamExtend4.1-FloatingObject-Divergence |
June 26, 2023, 08:24 |
Amirhossein Taran
Rep Power: 10 |
Hi Foamers,
Recently, I've been trying to solve the floatingObject test case in foam-extend-4.1. The built-in tutorial works well without any divergence. However, when I try to change the mass from 9.6 (the default value in the case) to 3.14 and update the moment of inertia based on this new value, I am facing a strange behavior. The box starts to submerge into the water, although its density is smaller than the water's density, and the solution diverges right after this submerging. I suspect there is a problem with the definition of mass in foam-extend, but I am unable to tackle the problem. Does anyone have a similar experience with this? Best regards, Amirhossein. |
floating object, foamextend-4.1, interdymfoam |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 4 | September 25, 2023 07:10 |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 7, 2021 23:17 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
