June 24, 2023, 07:36 |
pressure in interFoam
Rep Power: 4 |
interFoam is a solver for 2 incompressible, isothermal immiscible fluids using a VOFmethod.
The pressure is defined as: Code:
dimensions [1 -1 -2 0 0 0 0] Code:
dimensions [0 2 -2 0 0 0 0]; |
June 26, 2023, 12:04 |
Amirhossein Taran
Rep Power: 10 |
Greetings,
interFoam works with a p_rgh, which includes the hydrostatic contribution, so p_rgh = p - rho*gh; Altough i didnt understand your question, but hope this helps. Bests, |
June 26, 2023, 12:12 |
Rep Power: 4 |
If you run the dambreak tutorial you will see negative values of p_rgh. What does it mean? -x Pa bellow some reference value?
June 26, 2023, 13:19 |
Rep Power: 14 |
It means that the value of p_rgh is less than zero! You can manipulate the value of p_rgh (eg make it positive, or make it equal the static pressure at a certain location) by simply choosing a different reference height, hRef.
June 27, 2023, 04:14 |
Rep Power: 6 |
I think interFoam needs p_rgh to take the hydrostatic effetcs into account, but it does not need "realistic" values for the pressure, simply gradients. I may be wrong though!
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 15:00 |
Pressure reference in cyclic interFoam | AlmostSurelyRob | OpenFOAM | 7 | February 16, 2011 10:58 |
interFoam pressure conservation | AndrewB | OpenFOAM | 0 | August 27, 2009 00:15 |
