Limit temperature with compressibleInterFoam?
Old   June 22, 2023, 09:20
Question Limit temperature with compressibleInterFoam?
S Abrahams
sabrahams is on a distinguished road
Hi everyone!
It appears from this post in 2021 that it was not possible to limit temperature when using compressibleInterFoam:
https://bugs.openfoam.org/view.php?id=3737
Does anyone know if this is still the case or if there are any OF versions that now allow the temperature to be limited in compressibleInterFoam?
I'm currently using compressibleInterFoam in OF9. I was trying to limit temperature using fvConstraints. This is my fvConstraints code:
limitTwater
    type            limitTemperature;
    fields         (T);
    selectionMode   all;
    min             200;
    max             400;
    phase           water;
limitTvapour
    selectionMode   all;
    min             200;
    max             400;
    phase           vapour;
I get the same warning as in the linked post above:
 Constraint limitTwater defined for field e.water but never used
Can anyone give any advice on how I may be able to limit the temperature please?
sabrahams is offline   Reply With Quote
compressibleinterfoam, fvconstraints, fvoptions, limit, temperature
Weird (unphysical) temperature rise with chtMultiRegionFoam Phil910 OpenFOAM Running, Solving & CFD 3 November 9, 2022 10:25
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit RPjack ANSYS Meshing & Geometry 1 June 20, 2019 08:11
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
