Solving Parallel Plate Flow with icoFoam
Old   June 22, 2023, 03:05
Default Solving Parallel Plate Flow with icoFoam
Johannes
roo1valk is on a distinguished road
Good day all,
I am trying to run a simple parallel plate flow case using the icoFoam solver. However, I am getting a strange result for my velocity field, shown in the image below. I have had a look at the icoFoam - Elbow tutorial, which I understand to have similar boundary conditions. I suspect I might be missing something really simple, but cannot figure out what is wrong. I have tried a few different combinations of boundary conditions. Any pointers would be greatly appreciated. My blockMeshDict, p and U files are included below.
My blockMeshDict file body:
scale 1;
vertices
(0.01 0.005 -0.1)
(-0.01 0.005 -0.1)
(-0.01 -0.005 -0.1)
(0.01 -0.005 -0.1)
(0.01 0.005 0.1)
(-0.01 0.005 0.1)
(-0.01 -0.005 0.1)
(0.01 -0.005 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (4 1 40) simpleGrading (1 1 1)
edges
boundary
fixedWalls
type wall;
faces
(1 5 4 0)
(3 7 6 2)
frontback
type empty;
faces
(2 6 5 1)
(0 4 7 3)
inlet
type patch;
faces
(0 3 2 1)
outlet
type patch;
faces
(4 5 6 7)
My boundary conditions for p:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
fixedWalls
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
frontback
type empty;
My boundary conditions for U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
fixedWalls
type noSlip;
inlet
type fixedValue;
value uniform (0 0 1);
outlet
type zeroGradient;
frontback
type empty;
File Type: png Screenshot from 2023-06-22 07-49-59.png (12.0 KB, 7 views)
roo1valk is offline   Reply With Quote
Old   June 22, 2023, 19:07
Peter Hess
peterhess is on a distinguished road
Hello!,
4 cell in x direction is too few. Increase the number to, lets say, 10.
I suppose the y direction is the empty one. In this case one cell is sufficient.
The velocity in z direction should be -1 instead of 1, if the inlet at the top. Else it is right.
The velocity at the outlet should be changed to inletOutlet instead of zeroGradient.
Regards
Peter
peterhess is offline   Reply With Quote
Old   June 23, 2023, 01:40
Johannes
Hi Peter,
Thank you for your reply. My inlet is at the bottom, thus I kept it at 1 m/s (+Z). Velocity at the outlet is now an inletOutlet boundary condition. I also realized that my fixedWalls (noSlip condition) and frontback (empty condition) was swapped around, i.e. only one cell between my noSlip walls. I made the changes and now it works, screenshot of velocity field attached.
Kind regards,
Johannes
File Type: png Screenshot from 2023-06-23 06-33-43.png (13.6 KB, 6 views)
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
