compressibleInterFoam stopping without any error
Old   June 16, 2023, 05:58
Default compressibleInterFoam stopping without any error
Shanu
chaudhad is on a distinguished road
Hi guys,
I am doing a 2-phase simulation using compressibleInterFoam with LES as my turbulence model. The geometry is quite simple. it is a cylinder of 25.9mm radius and 906 mm length. Air is initially filled inside and then water starts to fill the cylinder from the bottom to compress the air inside. Simulations have already been done before with this case but they used blockMesh to mesh the geometry. I am using snappyHexMesh to mesh my geometry but when I make my mesh coarse without adding the boundary layers, the results are a bit different, and when I try to make it fine with the addition of boundary layers like 15 in this case, the solver stops without any error. I can also see that it is taking very large iteration to converge for p_rho, but I don't know what can I do. I have attached all the files below. please any help would be highly appreciated.
o folder
alphat
| \\ / O peration | Version: v1912 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 1e-11;
boundaryField
"(cylinderWalls|topX|bottomX|topY|bottomY|topZ|bot tomZ)"
type compressible::alphatWallFunction;
value uniform 0;
pipeWalls
value uniform 0;
top
value uniform 0;
inlet
type calculated;
value uniform 0;
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
type nutUWallFunction;
value uniform 0;
pipeWalls
value uniform 0;
top
value uniform 0;
inlet
type calculated;
value uniform 0;
chaudhad is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
