Force discontinuity with correctPhi in restart
Old   June 16, 2023, 05:54
Default Force discontinuity with correctPhi in restart
Dave
daveatstyacht is on a distinguished road
Hi All,
I am testing a modified version of pimpleFoam in which I impose the deformation of one of the boundary walls. The case is essentially the cavity tutorial case but with the left wall deforming in a proscribed manner from another code.
The solver works fine if I run without stopping the computation. However if I decide to stop and restart the computation I have a discontinuity in the fluid forces (about 2-3%). I observed that the residuals of the mesh deformation, pcorr and the momentum Ux and Uy are perfectly matching at the first non-linear iteration of the restarted case compared to the non-restarted case. The first difference that appears is the initial pressure residual. The deformation applied to the wall is identical for both the non-restarted case and restarted case, so I can eliminate issues from the other code as the source of the problem.
After numerous test, I have observed that if I deactivate correctPhi, then there is a perfect match between the forces of the restarted case and the case run without stopping. As I understand, if I leave correctPhi deactivated, I will be violating continuity and it will be worse if I increase the deformations. Clearly the problem comes from the restart of correctPhi and phi. I have not found a PIMPLE keyword that manages to compensate and adding inner loop iterations doesn't really help either. I already have 20 outer loop iterations. I am using Euler for the temporal scheme.
Is there something that should be saved that I am unaware of (for instance dPhi/dt)? Any ideas of how to address this are welcome.
Best regards,
Dave
daveatstyacht is offline   Reply With Quote
Old   June 16, 2023, 09:17
Default Influence of time scheme
Dave
Hi All,
As I mentioned in my prior post, I was using Euler for the temporal scheme in OpenFOAM. On a hunch I decided to test with Backward and my error almost entirely disappeared (0.0013% vs 2-3%). I am quite surprised that Euler would lead to a discontinuity and backward did not as if Euler was missing something during the save (cellDisplacement, p; phi, meshPhi, U, and Uf are all present).
I should add that the coupled code is advancing with second order (Newmark scheme). Is it possible that the mismatch in temporal scheme order is sufficient to cause a discontinuity even though the fluid solver received the same positions in both a restart or case without restart?
Best regards,
Dave
fsi restart, phi openfoam, restarting
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 07:04
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Force can not converge colopolo CFX 13 October 4, 2011 23:03
