codedMixed BC runs fine in serial run but crashes in parallel run |
June 15, 2023, 23:58 |
parth
Rep Power: 6 |
I am trying to implement codedMixed boundary condition at the fluid-solid interface to emulate boiling heat transfer. During Tw<Tsat I compare Q_solid = - Q_fluid, similar to turbulentTemperatureRadCoupledMixed boundary condition. However, during Tw>Tsat conditions, I compare Q_solid = - Qboiling. Where Qboiling is obtained from the boiling heat transfer correlations.
Now, this boundary condition works fine for the serial runs. However, I get sigSegv error for parallel run. Can anybody help me where I am doing wrong? Below is the implementation of the codedMixedBC: Code:
vessel1_to_water { type codedMixed; value uniform 300; name temperatureHeatFluxvessel1; refValue uniform 300; refGradient uniform 0; valueFraction uniform 0; //1 - Dirictlect ; 0 - Neumann code #{ // constant saturation temperature const scalar Tsat = 373.15; // k scalar kf = 0.5; // w/m/k, thermal conductivity of water scalar l = 0.36; // m const scalar Tchf = 273.15 + 100 + 30; // chf temperature scalar mul = 1.67e-3; // Pa.s, viscosity of water scalar hfg = 40.63e3; // J/mol, enthalpy of vaporization scalar rhov = 0.5782498; // water vapor density scalar rhol = 1000; // water density scalar sigma = 0.0589; // N/m, surface tensino of liquid-vapor interface scalar Csf = 0.0130; // experimental constant that depends on surface-fluid combination scalar Cpl = 4184; // J/kg/k, specific heat capacity of water scalar Pr = 6.9; // Prandtl of water scalar g = 9.81; // gravitational acceleration constant scalar ks = 16; // w/m/k, thermal conductivity of solid, steel scalar Tmin = 273.15 + 100 + 150; // min temperature scalar kg = 0.025; // W/m K, water vapor thermal conductivity scalar mug = 1.0016e-3; // water vapor viscosity. const fvMesh &solidFvMesh = db().parent().objectRegistry::lookupObject<fvMesh>("vessel1"); const volScalarField &solidT = solidFvMesh.thisDb().objectRegistry::lookupObject<volScalarField>("T"); const scalarField Ts = solidT.boundaryField()[solidFvMesh.boundaryMesh().findPatchID("vessel1_to_water")]; const fvPatch& patchsolid = solidFvMesh.boundary()[solidFvMesh.boundaryMesh().findPatchID("vessel1_to_water")]; const fvMesh &liquidFvMesh = db().parent().objectRegistry::lookupObject<fvMesh>("water"); const volScalarField &liquidT = liquidFvMesh.thisDb().objectRegistry::lookupObject<volScalarField>("T"); const fvPatch& patchwater = liquidFvMesh.boundary()[liquidFvMesh.boundaryMesh().findPatchID("water_to_vessel1")]; scalarField& Tp_(*this); scalarField Tgradient = Tp_ * scalar(0); scalar Tg = 0; forAll(Tp_, i) { if (Tp_[i] < Tsat) { this->refValue()[i] = Tp_[i]; this->refGrad()[i] = 0.0; this->valueFraction()[i] = (kf*patchwater.deltaCoeffs()[i])/(kf*patchwater.deltaCoeffs()[i] + ks * patchsolid.deltaCoeffs()[i]); } else if ((Tp_[i] > Tsat) && (Tp_[i] < Tchf)) { // Info << "Tp_ water" << mul * hfg * pow( g * (rhol-rhov)/sigma,0.5)* pow(Cpl*(Tp_[i]-Tsat)/Csf/hfg/Pr,3) <<endl; //* pow(Cpl*(Tp_[i]-Tsat)/Csf/hfg/Pr,3) this->refValue()[i] = Ts[i] -mul * hfg * pow( g * (rhol-rhov)/sigma,0.5) * pow(Cpl*(Tp_[i]-Tsat)/Csf/hfg/Pr,3) / (patchsolid.deltaCoeffs()[i] * ks); this->refGrad()[i] = 0; this->valueFraction()[i] = 0.0; } else if (Tp_[i]> Tchf) { Info << "Temperature exceeded" << endl; } } #}; codeInclude #{ #include "solidThermo.H" #include "fluidThermo.H" #include "fvCFD.H" #include "addToRunTimeSelectionTable.H" #include "fvPatchFieldMapper.H" #include "volFields.H" #include "mappedPatchBase.H" #include "basicThermo.H" #include "mappedPatchFieldBase.H" #}; codeOptions #{ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; } |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Big Difference Between Serial run and Parallel run case | alundilong | OpenFOAM Programming & Development | 1 | March 20, 2013 15:52 |
Parallel runs with sonicDyMFoam crashes (works fine with sonicFoam) | jnilsson | OpenFOAM Running, Solving & CFD | 0 | March 9, 2012 06:45 |
