June 15, 2023, 09:31 |
Fluctuations in Forces in OpenFOAM
Joana Viegas
Hello.
I'm running a simulation of a funnel, in a cylindrical domain, using RANS in combination with κ-ω SST model. After developing several meshes using ANSA, due to problems with high yPlus values, I've managed to get good values, and converging residuals. The only thing that's not according to my expectations is the forces I'm getting. I used a python script to calculate these, and attached are the forces vs Iteration. Is this acceptable? Considering there's some recirculation and separation of the flow, some fluctuations are expected, but I believe this is not the case. I've also attached my residuals. https://ulisboa-my.sharepoint.com/:f...eaJIg?e=jWdkA5 |
June 16, 2023, 03:06 |
Ilan
Rep Power: 7 |
Hello Joana,
It's difficult to answer your question without more details. Could you be more precise about your simulation and include some screenshots ? Nevertheless, you are using a dynamic model, the variations are not shocking to me. For Fx for example, the variation is "only" 3%. Also, forces in the y and z directions seems very weak compared to Fx. Also, what is the time step of the plots ? Have you investigated the pressure field on your structure to try to understand the origin of this variation ? What do you mean by : "developing several meshes using ANSA". Is it a mesh convergence study ? Hope I can help, Have a good day |
Lift drag forces and coefficients in OpenFOAM | milad1990 | OpenFOAM Post-Processing | 4 | September 17, 2022 11:30 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
Forces calculated by OpenFoam very strange | tta223 | OpenFOAM Post-Processing | 3 | August 5, 2017 09:10 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
Get the total Forces in OpenFOAM | HHOS | OpenFOAM Post-Processing | 0 | July 31, 2013 08:54 |
