Ferrofluid Modelling
Old   June 13, 2023, 02:48
Default Ferrofluid Modelling
Chaitanya
cyasing17 is on a distinguished road
Since ferrofluid is a non-Newtonian magnetic fluid, I was wondering if it was possible to do a Multiphysics simulation here in OpenFOAM of a ferrofluid interacting with water and solid. Due to the movements of the ferrofluid, there will be changing magnetic fields around it, which I want to capture using a coil. I am new to the software, so I wanted to know if such a simulation is possible with it.
Basically, it will be multiphase flow between Newtonian and non-Newtonian fluids (air-water, water-ferrofluid, maybe air-ferrofluid as well). Then a fluid-solid interaction needs to be coupled (the ferrofluid will be in a half-open solid structure, imagine a ). Finally, the Electromagnetic solver needs to be added for the coil.
I know it is a lot, but can I achieve this using OpenFOAM?
cyasing17 is offline   Reply With Quote
cfd - post, electrodynamics
How much does the source code for this turbulent flow CFD code worth in US $? Dr Youssef Hafez Main CFD Forum 43 January 4, 2023 02:13
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Low-Re Modelling doerschlott OpenFOAM Running, Solving & CFD 4 June 23, 2022 07:53
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 05:59
Ferrofluid flow modelling in fluent Souviktor FLUENT 1 January 10, 2016 05:21
