P diverging pointwise
Old   June 5, 2023, 13:10
Exclamation P diverging pointwise
Silvia Sambuca
checasino is on a distinguished road
Hi everybody, I am trying to simulate an industrial symmetryc air duct with incompressible steady state algorithm (SIMPLE). The mesh is very fine and it's tethraedrical (1 mm max size and 0.5 mm for min size for a 8 meters duct). At some point of the simulation some cells near the inlet diverge by increasing too much the pressure for no reason. (see attached pics)
Did anybody have the same problem? If you need I can also send Bcs, fvschemes and fvsolution files.
I also attached an image of the internal part of the duct (quite complex with support beams).
checasino is offline   Reply With Quote
Old   June 5, 2023, 13:32
Domenico Lahaye
dlahaye is on a distinguished road
Reduce relaxation factor in system/fvSolution ?
dlahaye is offline   Reply With Quote
Old   June 6, 2023, 04:48
Silvia Sambuca
right now the relaxation is 0.2 for p and the turbulent parameters and 0.3 for U . Isn't it enough?
air, duct, mesh, pressure, simple
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces Hamid.de Pointwise & Gridgen 4 November 9, 2016 12:20
[Commercial meshers] Pointwise to Foam - cyclic BC points order Pj. OpenFOAM Meshing & Mesh Conversion 5 August 14, 2016 05:47
CAD for Pointwise import giangcoikx Pointwise & Gridgen 1 July 19, 2016 11:59
[Commercial meshers] Native OpenFOAM interface in Pointwise cnsidero OpenFOAM Meshing & Mesh Conversion 41 May 20, 2012 19:30
Native OpenFOAM interface in Pointwise Chris Sideroff Main CFD Forum 0 January 16, 2009 13:37
