Dictionary Error for binaryAbsorptionEmission
Old   May 30, 2023, 17:53
Question Dictionary Error for binaryAbsorptionEmission
Peter Bevington
pbevington is on a distinguished road
Hi all, I'm getting an error while trying to use the binaryAbsorptionEmission model for radiation modeling:
Selecting radiationModel fvDOM
Selecting absorptionEmissionModel binaryAbsorptionEmission
--> FOAM FATAL IO ERROR: (openfoam-2012)
Entry 'model1' not found in dictionary "/scratch1/09374/pbevingt/OpenFOAM2012/run/coalJet/constant/radiationProperties"
file: /scratch1/09374/pbevingt/OpenFOAM2012/run/coalJet/constant/radiationProperties at line 18 to 97.
    From Foam::dictionary &Foam::dictionary::subDict(const Foam::word &, Foam::keyType::option)
    in file db/dictionary/dictionary.C at line 557.
FOAM exiting
'model1' is a submodel for the binaryAbsorptionEmission model, defined in the constant/radiationProperties dictionary:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      radiationProperties;
radiation       on;
radiationModel  fvDOM;
P1Coeffs
    C               C [0 0 0 0 0 0 0] 0;
fvDOMCoeffs
    nPhi        4;      // azimuthal angles in PI/2 on X-Y.(from Y to X)
    nTheta      2;      // polar angles in PI (from Z to X-Y plane)
    tolerance   0.05;   // convergence tolerance for radiation iteration
    maxIter     1;      // maximum number of iterations
// Number of flow iterations per radiation iteration
solverFreq 10;
absorptionEmissionModel binaryAbsorptionEmission;
binaryAbsorptionEmissionCoeffs
    model1
        absorptionEmissionModel wsggAbsorptionEmission;
        constantAbsorptionEmissionCoeffs
            absorptivity    absorptivity    [0 -1 0 0 0 0 0] 0.5;
            emissivity      emissivity      [0 -1 0 0 0 0 0] 0.5;
            E               E   [1 -1 -3 0 0 0 0] 0;
        greyMeanAbsorptionEmissionCoeffs
            lookUpTableFileName     none;
            EhrrCoeff               0.2;
        wsggAbsorptionEmissionCoeffs
            meanBeamPathAutoCalcMode true;
            sector sector    [ 0  0  0  0  0  0  0] 360.0; //Degrees
            pathLength pathLength [ 0 1  0  0  0  0  0]  0.1; //m
            emissivityCoeffs 3(  0.4201 6.516 131.9 );
            fittingFactors
            3
                4(6.508e-1 -5.551e-4 3.029e-7  -5.353e-11)
                4(-0.2504e-1  6.112e-4  -3.882e-7  6.528e-11)
                4(2.718e-1 -3.118e-4  1.221e-7  -1.612e-11)
    model2
        absorptionEmissionModel cloudAbsorptionEmission;
        cloudAbsorptionEmissionCoeffs
            cloudNames
                coalCloud1
scatterModel    none;
cloudScatterCoeffs
    cloudNames
        coalCloud1
transmissivityModel none;
As you can see, model1 is defined as within the dictionary file, so I'm confused as to why this error would be showing up. Any ideas? For reference, here is the binaryAbsorptionEmission constructor, as defined in binaryAbsorptionEmission.C:
 Foam::radiation::binaryAbsorptionEmission::binaryAbsorptionEmission
     const dictionary& dict,
     const fvMesh& mesh
     absorptionEmissionModel(dict, mesh),
     coeffsDict_(dict.optionalSubDict(typeName + "Coeffs")),
     model1_
         absorptionEmissionModel::New(coeffsDict_.subDict("model1"), mesh)
     model2_
         absorptionEmissionModel::New(coeffsDict_.subDict("model2"), mesh)
pbevington is offline   Reply With Quote
Old   May 31, 2023, 06:32
Alczem is on a distinguished road
Hey
I am not familiar with this model, but did you try to define model1 and model2 outside of binaryAbsorptionEmissionCoeffs? The way the error is written lets me think that it might just be a matter of indentation. Maybe try this:
radiation       on;
P1Coeffs
fvDOMCoeffs
solverFreq 10;
model1
        EhrrCoeff               0.2;
        fittingFactors
        3
model2
        cloudNames
            coalCloud1
I can't see any other reason right now sorry
Alczem is offline   Reply With Quote
Old   May 31, 2023, 18:58
Peter Bevington
I tried that playing around with the dictionary format, though I don't think that is it, as I found a tutorial for coalChemistryFoam that uses the above format and works just fine. This is from tutorials/lagrangian/coalChemistryFoam/simplifiedSiwek:
|  \\    /   O peration     | Version:  v2212                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
solverFreq      1;
radiationModel  P1;
P1Coeffs
    model1
        absorptionEmissionModel constantAbsorptionEmission;
    model2
            cloudNames
                coalCloud1
                limestoneCloud1
scatterModel    cloudScatter;
cloudScatterCoeffs
    cloudNames
        coalCloud1
        limestoneCloud1
I even copied that radiationProperties dict exactly to my case, but to no success. My next thought was that it had to be my solver, which is using a custom copy of the src/thermophysicalModels/radiation library. However, compiling with the native radiation library gave no change in behavior...
For reference the error is occuring when we are trying to unpack the subDicts model1 and model2 of the CoeffsDict:
(src/thermophysicalModels/radiation/submodels/absorptionEmissionModel/binaryAbsorptionEmissionModel/binaryAbsorptionEmission.C):
     const fvMesh& mesh
     model1_
         absorptionEmissionModel::New(coeffsDict_.subDict("model1") <-Error is occuring when calling subDict("model1") on the CoeffsDict, mesh)
     model2_
I cannot for the life of me figure out why I would get different behavior with the same radiationProperties dictionary and the same radiation library code. Perhaps there is some other dictionary that affects the radiation model?
Dictionary in turbulence model NewKid OpenFOAM Programming & Development 4 February 18, 2019 22:16
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 04:58
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
FoamX error aachenBomb case Ervin Adorean (Adorean) OpenFOAM Pre-Processing 13 March 7, 2005 04:50
