issues with multiphaseEulerFoam solver for binary simulation in fluidized beds
Old   May 15, 2023, 22:46
Unhappy issues with multiphaseEulerFoam solver for binary simulation in fluidized beds
Esmaeel
Esmaeel is on a distinguished road
Hi everyone, I am trying to study the particle size effects for a binary mixture in a fluidized beds. So the system is particle-fluid but we have three phases: particle1,particle2, and air. The problem that I am facing with multiphaseEulerFoam solver is that the air volume fraction goes below 0.38 and it becomes as low as 0.24. So, each particle volume fraction are around 0.37 for same cells and that leads to the high volume fraction for particle phase. Here is the phaseProperties dictionary. Can anyone please help me understand what is wrong with my phaseProperties which results in high solid concentration? Thanks.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 10
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "constant";
object phaseProperties;
type basicMultiphaseSystem;
phases ( particles particles2 air );
//referencePhase particles;
particles
type purePhaseModel;
diameterModel constant;
constantCoeffs
d 2e-4;
alphaMax 0.62;
residualAlpha 1e-6;
particles2
constantCoeffs
d 2e-4;
alphaMax 0.62;
residualAlpha 1e-6;
air
diameterModel none;
residualAlpha 0.;
alphaMin 0.38;
blending
default
type continuous;
phase air;
surfaceTension
interfaceCompression
drag
particles_dispersedIn_air
type Ergun;
residualRe 1e-3;
particles2_dispersedIn_air
type Ergun;
residualRe 1e-3;
virtualMass
heatTransfer
type RanzMarshall;
residualAlpha 1e-4;
type RanzMarshall;
residualAlpha 1e-4;
phaseTransfer
lift
wallLubrication
turbulentDispersion
Esmaeel is offline   Reply With Quote
Old   May 16, 2023, 03:20
Utkan Caliskan
dscian is on a distinguished road
kineticTheoryModel is important for particle dynamics in multiphaseEulerFoam so you need to check that. Furthermore, I don't think current solver can handle two different particle phases properly.
dscian is offline   Reply With Quote
Old   May 16, 2023, 03:38
Esmaeel
Thanks for the reply. The current case is from fluidized bed tutorial and it uses RAS kinetickTheory. I am beginning to accept that two particle systems cannot be modeled with this solver but I might be wrong!
Old   June 5, 2023, 15:28
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
The kineticTheory implementation requires major changes to be able to model multiple solid dispersed phases. In the present state it should be used only with one solid phase.
demichie is offline   Reply With Quote
Old   June 7, 2023, 01:17
Esmaeel
Thanks. I was wondering if other software like ANSYS-CFX or MFIX can do such modeling of multi-particle systems with euler-euler approach?
Old   June 7, 2023, 02:24
Yes, they can both model multi-particle systems. If you want to do that with OpenFOAM, you have to modify the kinetic class in multiphaseEuler (the main change is the in the radial distribution functions), add a model for a multi-particle maximum packing, and add a solid-solid drag.
Old   June 7, 2023, 02:41
Esmaeel
I prefer to stick with OpenfFOAM. I would really appreciate if you could explain more on where/how the changes should be made? I have some experience with modifying solvers/libraries but this multiphaseEulerFoam is complicated/confusing!cheers
Is pressure-based solver adequate for a transient simulation ? y__tb FLUENT 1 May 24, 2022 00:15
solver selection_dynamic mesh_leak simulation nikhil108 OpenFOAM Programming & Development 1 August 13, 2020 18:14
solver selection_dynamic mesh_leak simulation nikhil108 OpenFOAM Running, Solving & CFD 5 August 13, 2020 18:12
How can I use solution from one simulation as initial condition on a remote solver? Dano62 CFX 0 October 21, 2015 18:45
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
