rhoCentralFoam Case Blowing Up
Old   May 8, 2023, 16:48
Exclamation rhoCentralFoam Case Blowing Up
Sakun
Sakun is on a distinguished road
Hello everyone,
I am trying to simulate my high-speed single blade simulation in rhoCentralFoam. It is running for couple of iterations and suddenly crash. Error that generate doesn't give much information either.
I need to run this case using kOmega SST and i have attached fvSchemes and fvSolution files below.
Please someone help me on this issue?
Error that generated;
deltaT = 4.11195e-09
Mean and max Courant Numbers = 0.00342632 1.6291
Time = 6.09249e-07
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 4.96493e-05, Final residual = 5.54071e-07, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 5.67593e-05, Final residual = 7.83343e-07, No Iterations 2
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libc.so.6
#3  ? in /lib/x86_64-linux-gnu/libm.so.6
#4  ? at ??:?
#5  ? at ??:?
#6  ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam
#7  ? in /lib/x86_64-linux-gnu/libc.so.6
#8  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#9  ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam
Floating point exception (core dumped)
fvSchemes;
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
fluxScheme          Kurganov;
ddtSchemes
    default             Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
    div(phi,U)      Gauss Minmod;
    //div(phi,U)      Gauss linearUpwind limitedU;
    //div(phi,U)      Gauss linearUpwindV limitedU;
    //div(phi,U)      Gauss upwind;
    turbulence1      Gauss linear;
    turbulence2      Gauss linearUpwind limitedT;
    turbulence3      Gauss limitedLinear 1;
    div(phi,k)      $turbulence1;
    div(phi,omega)  $turbulence1;
    energy1         Gauss linearUpwind limitedE;
    energy2         Gauss limitedLinear 1;
    energy3         Gauss LUST limitedE;
    energy4         Gauss linear;
    div(phi,e)        $energy4;
//enthalpy -> h
    div(phi,h)      $energy2;
    div(phi,K)      $energy2;
    //div(phid,p)     Gauss upwind;
    //div(phid,p)     Gauss LUST default;
    div(phid,p)     Gauss limitedLinear 1;
    div(phiv,p)        Gauss limitedLinear 1;
    //div(phid,p)     Gauss MUSCL;
    div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    reconstruct(rho) vanLeer;
    reconstruct(U)  vanLeerV;
    reconstruct(T)  vanLeer;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
fvSolution;
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "(rho|rhoU|rhoE)"
        solver          diagonal;
    "(rho|U|h|k|e|omega)"
        solver          smoothSolver;
        smoother        GaussSeidel;
        nSweeps         2;
        tolerance       1e-06;
        relTol          0.01;
relaxationFactors
    fields
        p             0.3;
        rho           0.1;
    equations
        U                       0.5;
        h                       0.5;
        "(e|k|omega)"     0.5;
Thank you very much for your valuable time
Sakun is offline   Reply With Quote
Old   September 12, 2023, 03:18
Furkan
Homogenic is on a distinguished road
I have also obtained the same set of errors using reactingFOAM for a combustion simulation. Try reducing the time-steps and the maximum Courant number in your solution, that was the problem in my case.
Regards.
Homogenic is offline   Reply With Quote
Old   September 13, 2023, 06:12
Sakun
Regards.
Thank you very much for the reply,
I did actually tried those options but not succeeded
Old   July 28, 2024, 13:46
chc
chc is on a distinguished road
I don’t know if you’re still working on this, but I think the use of relaxation factors in your fvSolutions may be impacting your results. Since rCF is a transient solver, using relaxation would skew that and possibly induce some errors. Other than that, since your time step is dropping low, another possibility is it could be a result of poor mesh quality or skewed cells.
chc is offline   Reply With Quote
compressible flow, compressor blade, periodic condition, unsteady
Correct way of defning thermophysicalProperties for rhoCentralFoam vachan OpenFOAM Programming & Development 1 May 13, 2022 14:55
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Reporting a bug in Allrun script on wingMotion case i.sabahi OpenFOAM Bugs 0 June 10, 2018 10:00
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 12:20
