May 8, 2023, 08:41 |
guidelines for dynamicMesh for piston motion
Zeinab
Rep Power: 3 |
Hello guys,
I need to simulate the motion of a piston that has the motion shown in the figure below. pistonDrawing.PNG so basically the piston doesn't press on the whole fluid region, there are liquid surrounding the piston. In this problem, I know that I need mesh motion + topology changes (sliding interface and layer addition/removal). I saw many videos and many posts on this forum but I am still confused. My questions are: 1. Is there a dynamic mesh library that can work with this problem directly? (I tried Code:
solidBodyMotion Code:
dispalcementLayeredMotion 2. If there is not a direct library to use? what libraries shall I combine their features? and I want some guidelines in this process. Thank you so much. |
February 4, 2024, 09:24 |
Michael Sukham
Rep Power: 6 |
Why don't you try linearValveLayersFvMesh from foamExtend. They do have that feature of attach-detach, sliding and layer addition removal. Note: These library compiles only in foamExtend.
dynamicmesh, engine, layer addition/removal, piston, sliding interface |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 05:27 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 12:37 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
