fvModel - accelerationSource - No periodic flow |
May 7, 2023, 22:42 |
Nazmul Islam
Rep Power: 3 |
I am trying to simulate oscillating flow of a viscous incompressible fluid through periodic tubes by using the solver pimpleFoam. I have applied cyclicAMI periodic boundary condition at the inlet and outlet. Also, I have used accelerationSource fvModel with sine function to create sinusoidally oscillating flow, as you can see below: accelerationSource1 { type accelerationSource; selectionMode all; U U; velocity scale; value (1 0 0); scale { type sine; frequency 1; amplitude 1; scale 1; level 0; } } Although the flow is now sinusoidally oscillating, but it is not the same for each oscillation. Is there any way to create sinusoidally oscillating flow through a periodic tube so that the flow will be same for each oscillation? I appreciate your suggestion in this regard. Cheers, Nazmul |
Periodic boundary condition on coil flow | Vestdam | FLUENT | 3 | May 10, 2022 05:44 |
Translational+rptational periodic flow | Shamoon Jamshed | FLUENT | 0 | June 1, 2017 22:03 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 1 | October 17, 2012 07:06 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 0 | September 19, 2012 04:21 |
specifying the flow direction in periodic boundary | joanna | FLUENT | 2 | February 27, 2006 22:09 |
