compressibleMultiphaseInterFoam with fvOptions Mass Source
Old   May 5, 2023, 04:35
Default compressibleMultiphaseInterFoam with fvOptions Mass Source
Kojote is on a distinguished road
i am struggeling to add some material via fvOptions. Did anyone here manage to add mass e.g. over a cellZone?
Thanks for helping me on that one.
Br
Christian
Kojote is offline   Reply With Quote
Old   May 5, 2023, 06:10
Paul Palladium
Fauster is on a distinguished road
Not sure to understand what you are trying to accomplish. You would like to simulate phase change ?
Fauster is offline   Reply With Quote
Old   May 5, 2023, 06:11
No i want to have a meshless inlet on a certain point.
Old   May 11, 2023, 09:17
Paul Palladium
You want to have a "boundary condition" on a certain point on your mesh for defining velocity, alpha, temperature etc.. ?
I dont think it's possible to do that on OpenFOAM. fvOptions class allows you to have source terms. For Momentum equation you will be able to define an acceleration source but this is not what you want to do. For energy it will be power source and so on.
Old   May 11, 2023, 11:43
Hi
thanks for the replay. I found code like this -->
Mass source sounds like what i want to do.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object fvOptions;
injector1
timeStart 0.1;
duration 5;
selectionMode points;
points
(0.075 0.2 0.05)
options
massSource1
type scalarSemiImplicitSource;
$injector1;
volumeMode absolute;
injectionRateSuSp
thermo:rho.air (1e-3 0); // kg/s
momentumSource1
type vectorSemiImplicitSource;
$injector1;
injectionRateSuSp
U.air ((0 -1e-2 0) 0); // kg*m/s^2
energySource1
$injector1;
injectionRateSuSp
e.air (500 0); // kg*m^2/s^3
Old   June 12, 2023, 22:26
FOAMraj
BIRAJ is on a distinguished road
Hello, for this you have to mention the region in the topoSet and introduce the source term in fvOption mentioning the same region you mentioned in the topoSet.
BIRAJ is offline   Reply With Quote
Old   May 27, 2024, 15:07
alberto
dewey is on a distinguished road
Originally Posted by Kojote View Post
Hi
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvOptions;
injector1
timeStart 0.1;
duration 5;
points
(0.075 0.2 0.05)
options
massSource1
$injector1;
injectionRateSuSp
momentumSource1
$injector1;
injectionRateSuSp
energySource1
$injector1;
injectionRateSuSp
Hello, I have a similar problem. Did you find a solution?
dewey is offline   Reply With Quote
Old   September 8, 2024, 07:00
Default Hint
Nicoḷ Badodi
NBad is on a distinguished road
Looking at the code of compressibleMultiphaseInterFoam it looks like fvOptions is not implemented into the equations. For example the equation for U is:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(mixture.rhoPhi(), U)
      + turbulence->divDevRhoReff(U)
What you can do is to look at the code of some other solver and implement fvOptions. For example multiphaseInterFoam has fvOptions included:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
      - fvm::Sp(contErr, U)
      + MRF.DDt(rho, U)
      + turbulence.divDevRhoReff(U)
        fvOptions(rho, U)
NBad is offline   Reply With Quote
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
