Oscillating flow by accelerationSource
Old   April 28, 2023, 02:38
Default Oscillating flow by accelerationSource
Nazmul Islam
nazmulislam is on a distinguished road
Hi all,
I am trying to investigate oscillating flow of a viscous incompressible fluid through periodic tubes. I have applied cyclicAMI periodic boundary condition at the inlet and outlet. Also, I have used accelerationSource fvModels with sine function to create sinusoidally oscillating flow, please see in the attachment.
Although the flow is now sinusoidally oscillating, but it is not the same for each oscillation (as I want). As I am using accelerationSource fvModels, the velocity components are accelerating in each oscillation, so the velocities are not the same in each oscillation.
Is there any way to create sinusoidally oscillating flow through a periodic tube so that the flow will be same for each oscillation?
I appreciate your suggestion in this regard.
Cheers,
Nazmul
nazmulislam is offline   Reply With Quote
Oscillating residuals in steady flow problem Mohit Singh Main CFD Forum 3 February 23, 2016 15:39
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 13:46
Flow oscillating device, FLUID141/FLUID142... BV Main CFD Forum 0 February 24, 2006 13:57
oscillating flow bb FLUENT 2 February 22, 2006 02:24
oscillating flow Glenn FLUENT 0 July 11, 2002 11:33
