Running a liquid nitrogen case with a film solver |
April 26, 2023, 04:46 |
Khaled Yassin
Rep Power: 7 |
Hey guys,
I am trying to run the rivuletPanel tutorial using buoyantReactingFoam and replacing the H2O liquid with liquid nitrogen. However, it shows the following error: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9 Exec : buoyantReactingFoam Date : Apr 26 2023 Time : 10:26:44 Host : "isr028" PID : 31425 I/O : uncollated Case : /loc_home/khaled/software/testing/rivuletPanel nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (file ModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in transient mode with 1 outer corrector PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture multiComponentMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating thermophysical transport model Selecting thermophysical transport type laminar Selecting default laminar thermophysical transport model unityLewisFourier Creating reaction model Selecting combustion model none Reading g Reading hRef Calculating field g.h Reading pRef Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present Creating fvModels from "constant/fvModels" Selecting finite volume model type surfaceFilm Name: surfaceFilm Selecting surfaceFilmModel thermoSingleLayer Selecting region model functions none PIMPLE: No convergence criteria found PIMPLE: No corrector convergence criteria found Calculations will do 2 corrections PIMPLE: Operating solver in transient mode with 2 outer correctors Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; properties liquid; energy sensibleInternalEnergy; } #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 ? in "/lib64/libm.so.6" #4 powf64 in "/lib64/libm.so.6" #5 Foam::N2::rho(double, double) const at ??:? #6 Foam::heRhoThermo<Foam::rhoThermo::composite, Foam::pureMixture<Foam::species::thermo <Foam::thermophysicalPropertiesSelector<Foam::liquidProperties>, Foam::sensibleInternalEn ergy> > >::calculate() at ??:? #7 Foam::heRhoThermo<Foam::rhoThermo::composite, Foam::pureMixture<Foam::species::thermo <Foam::thermophysicalPropertiesSelector<Foam::liquidProperties>, Foam::sensibleInternalEn ergy> > >::heRhoThermo(Foam::fvMesh const&, Foam::word const&) at ??:? #8 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo::compo site, Foam::pureMixture<Foam::species::thermo<Foam::thermophysicalPropertiesSelector<Foam ::liquidProperties>, Foam::sensibleInternalEnergy> > > >::New(Foam::fvMesh const&, Foam:: word const&) at ??:? #9 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh c onst&, Foam::word const&) at ??:? #10 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #11 Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::kinematicSingleLayer(Fo am::word const&, Foam::fvMesh const&, Foam::dimensioned<Foam::Vector<double> > const&, Fo am::word const&, bool) at ??:? #12 Foam::regionModels::surfaceFilmModels::thermoSingleLayer::thermoSingleLayer(Foam::wo rd const&, Foam::fvMesh const&, Foam::dimensioned<Foam::Vector<double> > const&, Foam::wo rd const&, bool) at ??:? #13 Foam::regionModels::surfaceFilmModel::addmeshConstructorToTable<Foam::regionModels:: surfaceFilmModels::thermoSingleLayer>::New(Foam::word const&, Foam::fvMesh const&, Foam:: dimensioned<Foam::Vector<double> > const&, Foam::word const&) at ??:? #14 Foam::regionModels::surfaceFilmModel::New(Foam::fvMesh const&, Foam::dimensioned<Foa m::Vector<double> > const&, Foam::word const&) at ??:? #15 Foam::fv::surfaceFilm::surfaceFilm(Foam::word const&, Foam::word const&, Foam::dicti onary const&, Foam::fvMesh const&) at ??:? #16 Foam::fvModel::adddictionaryConstructorToTable<Foam::fv::surfaceFilm>::New(Foam::wor d const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:? #17 Foam::fvModel::New(Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:? #18 Foam::fvModels::fvModels(Foam::fvMesh const&) at ??:? #19 ? at ??:? #20 ? at ??:? #21 __libc_start_main in "/lib64/libc.so.6" #22 ? at /home/abuild/rpmbuild/BUILD/glibc-2.31/csu/../sysdeps/x86_64/start.S:122 Gleitkomma-Ausnahme (Speicherabzug geschrieben) khaled@isr028:/loc_home/khaled/software/testing/rivuletPanel> ^C khaled@isr028:/loc_home/khaled/software/testing/rivuletPanel> cd /loc_home/khaled/softwa re/testing/rivuletPanel/0 I think OpenFOAM has a probelm obtaining the liquid properties in this case. Has anybody tried running liquid nitrogen as a film before and can share the case? Any ideas about why it is throwing this error? Attached my case. Regards, Khaled |
January 25, 2024, 00:18 |
Rep Power: 5 |
Hello,have you solved this problem?
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 7, 2021 23:17 |
Error while running annular boiling case | sabrinacarson | OpenFOAM Pre-Processing | 1 | April 19, 2019 14:39 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Liquid film solver. | sharonyue | OpenFOAM Running, Solving & CFD | 1 | July 22, 2015 11:13 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
