continuity error for pressure inlet and flowrate outlet |
Haizhou
Rep Power: 0 ![]() |
I am new to OpenFOAM and trying to run a laminar flow simulation using simplefoam with pressure inlet and flowrate outlet. However, I always get diverged results with large continuity errors. Any suggestions for this situation? The boundary condition files are attached below: U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type outletInlet; outletValue uniform (0 0 0); value uniform (0 0 0); } outlet { type flowRateOutletVelocity; volumetricFlowRate 5.676455641980107e-07; value uniform (0 0 0); } walls { type noSlip; } } P: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 12.3260377358; } outlet { type zeroGradient; } walls { type zeroGradient; } } Thanks in advance. Best, y |
continuity error, simplefoam convergence |
continuity error for pressure inlet and flowrate outlet | yhz37 | OpenFOAM Running, Solving & CFD | 0 | April 24, 2023 15:33 |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
massflow of inlet and outlet are not equal | knoedl1 | OpenFOAM Running, Solving & CFD | 11 | July 3, 2018 14:00 |
Flowrate at inlet and outlet not balancing ( centrifugal pump ) -- pimpleDyMFoam | coolcrasher | OpenFOAM Running, Solving & CFD | 20 | November 25, 2015 05:33 |
Fan simulation with inlet and outlet duct for finding fan curve | chaudhry_hashim | FLUENT | 0 | August 6, 2014 10:49 |
