Too fast heat release of engine simulation in OpenFOAM
Old   April 24, 2023, 10:41
Default Too fast heat release of engine simulation in OpenFOAM
jzy
金卓颖
jzy is on a distinguished road
I am doing the conventional diesel engine simulation in OpenFOAM, but the heat release rate computed from Qdot of combustion model of the appraent heat release rate are too high comparing with experiment. And the it worthy noted that the chemical heat release is too fast that the simulation automatically stops.
I have tried different chmistry mechanism and turbulence model or spray model constant, but the similar trend is not changed. However, for the single-step reaction of C7H16, the heat release and pressure is normal. So I want to know which parameters I need to change and the cause of this strange trend. The computed pressure and heat release rate are as attached pictures. The time step in combustion process is 0.002 CAD and the ode solution is applicated.
Thanks for any advices!
jzy is offline   Reply With Quote
Heat Release Rate in fireFoam ingraban OpenFOAM Post-Processing 3 October 6, 2022 11:41
Solvers in OpenFOAM for LES + heat transfer arun1994 Main CFD Forum 1 November 26, 2021 08:57
heat not balanced in the chtMultiRegionSimpleFoam solver carye OpenFOAM 19 September 26, 2019 05:25
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
