April 23, 2023, 16:47 |
Heat transfer in pipe not responding
Jacob
Rep Power: 3 |
I am trying to model air flowing through a pipe with hot walls however after I run the simulation nothing changes. The inlet is just a different temperature than the walls and outlet. I have tried to change the flow rate, temperatures, mesh size with not luck. I feel I may be missing something obvious.
I have copied the files to a share folder on google drive https://drive.google.com/drive/folde...e2?usp=sharing I followed this tutorial https://freecfdtutorial.blogspot.com...torial-01.html and got the results to work but when I adapt it to my geometry its not working. |
heat transfer |
No Display of Heat Transfer Graphs For Double Pipe Heat Exhanger in CFX Solver | Shomaz ul Haq | CFX | 17 | November 25, 2015 22:44 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
heat transfer along a pipe | lysander | FLUENT | 0 | July 27, 2012 23:39 |
