Mapped boundary condition for turbulent pipeflow
Old   April 20, 2023, 13:22
Default Mapped boundary condition for turbulent pipeflow
CFD_Lovers
sinatahmooresi is on a distinguished road
Hello FOAMers,
I am currently working on generating a fully developed turbulent velocity profile at the beginning of a jet nozzle to be discharged into a tank using LES simulation in OpenFOAM. To achieve this, I have tried incorporating a precursor simulation of pipe flow before the tank inlet. Among the various methods available, I have utilized the mapped inlet for velocity. However, I have noticed that the resulting velocity profile appears smooth and averaged, rather than the expected fluctuating instantaneous profile typical of LES simulations. I would appreciate any advice or suggestions on this matter. Attached are boundary, U, p, k, nut dictionaries and the resulted velocity profile. The simulation is conducted in 2D and I built the model for the most part based on the pitzDailyMapped tutorial. simulation is non-dimensional and thus the U=(1 0 0). The number of generated elements in horizontal and vertical directions are 2000 and 200 respectively. The non-dimensional length is 30 and the mapping source face is located at x=18 which is after the entrance length required for the flow to be fully developed (Re=3000).
Thank you,
Sina
sinatahmooresi is offline   Reply With Quote
Old   May 2, 2023, 23:50
CFD_Lovers
Greetings all,
I'm seeking advice from anyone who might have some suggestions. I've attempted to use both cyclic and mapped boundary conditions, as well as the perturbU utility for initialization, but have not achieved any success. It appears that the primary issue is that the turbulence does not transition from the wall to the center. Additionally, yplus remains below 5 to ensure proper wall capture.
Fatal overflow in linear solver. iamnotfajar CFX 9 October 28, 2020 05:47
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Boundary Condition For Mapped Fields in OpenFOAM Alhasan OpenFOAM Running, Solving & CFD 32 January 11, 2014 18:51
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
