Spiking residuals in simpleFOAM using k-omegaSST
Old   April 18, 2023, 07:55
Default Spiking residuals in simpleFOAM using k-omegaSST
Andrew Che
carche31 is on a distinguished road
Hi all,
I am relatively new to CFD and this is my first post. I am trying to simulate a 3D analysis of the airflow inside an oven chamber.
My first step is to just consider flow with a steady analysis and hence, I am using simpleFoam solver with the k-omegaSST turbulence model with wall functions.
My first few solves included a coarser mesh, and residuals weren't showing any abnormal behaviour. However upon increasing grid density, my residual plots for k and omega experience some weird behaviour (see attached image).
My k and omega files are also attached for inspection, as well as fvSolution and fvSchemes.
My yPlus was calculated to be between 0.4 and 200 for this particular case, and the areas affected are in the regions where yPlus is very low. Currently I am trying to use snappyHexMesh to control the cell thicknesses at the walls to be larger (still learning how to use this tool also!), incase this is the underlying issue.
Any insight into the root of the behaviour is much appreciated, and please forgive my ignorance. There is much more to learn! If you need more info please let me know!!
Cheers
carche31 is offline   Reply With Quote
komega sst model, mesh, residuals, wall functions
CyclicAMI & SimpleFoam results residuals =1 Polyzos OpenFOAM Running, Solving & CFD 0 October 21, 2020 08:14
Residuals not dropping in simpleFOAM. Manideep Reddy OpenFOAM Running, Solving & CFD 1 April 26, 2018 04:09
SimpleFoam: High residuals after increase in Reynolds Number JasonG OpenFOAM Running, Solving & CFD 21 October 5, 2017 11:11
Buoyantboussinesq simpleFoam residuals problem Naresh yathuru OpenFOAM Running, Solving & CFD 6 March 20, 2015 15:33
SimpleFoam - Interpretation of Residuals despaired student OpenFOAM Running, Solving & CFD 3 February 8, 2013 08:39
